Nokia 3100 flash Ic changing Bro's ! i need to know if i change da flash IC will emie b all 0000000000004? Or if it is ! how can i re programme d emie? Do i have to replace da UEM as well? [email protected] |
ask & rpl ............................................ :) |
for changing flash ic better upload software with aks and rpl file it will work surely ......... |
how i can write the rpl and ask filess |
to wirte an RPL file -------->plug ur phone to DCTX_BB5 for example , press write UEM ..! that is in brief. B.regards |
First,if the phone is alive.. you can backup IMei..as you write it agian... but if the phone is dead... its better to change UEM also for sure. that,the phone work Okey... |
i have 3100, dead, i try to flash, but it gives flash ic error, i reball it and again try on flashing, its 1st boot ok, but when flash it cant show full numbers of flash ic, now how to fix it? |
I'ts better to change a new flash ic...to fix it. |
as u said change new flash ic than in this case we have to change uem also?m i rite? |
