08-24-2005, 02:16 | #7 (permalink) | |
Insane Poster Join Date: Nov 2002 Location: Philippines Age: 45
Member: 17773 Status: Offline Thanks Meter: 6 | Quote:
Still same check first the buzzer then the terminal pads if not you to change the N150. BR, ricter | |
08-24-2005, 22:42 | #8 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | where is n150 and where is the conection from the 1 ohm resistor to next point, the resistor brake off, and need to solder fine wire to next point, from ring speaker ways. 3100, thank you |
08-24-2005, 23:50 | #9 (permalink) |
No Life Poster Join Date: Feb 2002 Location: burning phones
Member: 9700 Status: Offline Thanks Meter: 62 | if you have checked n150 and speaker and both are ok then check two small capacitors near buzzer pads, try to change it (same as 3100,6100) if not check uem. b.r. |
n73 loud speaker not working | ihabz1981 | Nokia Hardware & Hardware Repair | 4 | 04-29-2009 08:18 |
3100- loud speaker not working | rahmanp | Nokia Hardware & Hardware Repair | 4 | 08-09-2008 18:22 |
6230 Loud-speaker Not Working | beneto | Samsung Hardware Repair | 1 | 05-14-2008 01:34 |
6230 loud-speaker not working | beneto | Nokia Hardware & Hardware Repair | 0 | 05-14-2008 01:16 |
x66 after flash loud speaker not work | janjaroen | Infinity-Box | 2 | 04-06-2006 12:05 |
