Old 04-23-2007, 07:56   #1 (permalink)
Member: 248245
Thanks Meter: 85
Nokia 3100 signal
One Nokia 3100 no signal i change PA, Ant Switch but not solved pls given a suaitable solution.
Old 04-23-2007, 08:44   #2 (permalink)
Member: 278058
Thanks Meter: 81
Write pm file. If no success reheat Mjoelner.
Old 04-23-2007, 08:51   #3 (permalink)
umarnlw's Avatar
Member: 207708
Sonork: 100.1602241
Thanks Meter: 1,005
3100 signal problem 100%
janu
change the tx rx filters and enjoy the singals
Old 04-23-2007, 09:12   #4 (permalink)
Allunlockingsource's Avatar
Member: 333439
Sonork: 100.1589101
Thanks Meter: 623
Reheat hager ic .....................
Old 04-23-2007, 13:46   #5 (permalink)
Cheater -Don't Deal with him-
::gsmcoder::'s Avatar
Member: 172434
Sonork: 100.161280
Thanks Meter: 577
no instruction to check antenna connectors
Old 04-24-2007, 07:53   #6 (permalink)
yashtel's Avatar
Member: 170589
Thanks Meter: 1,848
Heat Or Replace Helgo Ic...............
Old 04-24-2007, 09:56   #7 (permalink)
Member: 420875
Thanks Meter: 23
write good pm if not done rebakk cpu 100% u succsec good luck.
Old 04-24-2007, 10:06   #8 (permalink)
kardelen gsm's Avatar
Member: 133173
Thanks Meter: 119
upp problem...regards
Old 04-24-2007, 16:54   #9 (permalink)
Member: 190856
Thanks Meter: 27
1st:write pm
2st:re hot hagar area all component one by one
3rd:replace confrom ok pa
4th:change hagar
5th:re hot uem
finally re hot cpu
i think solved ur prob thx
Old 04-24-2007, 20:25   #10 (permalink)
Dave.W's Avatar
Member: 7653
Thanks Meter: 823
test phone first!!
in all case!
man, my car will not start.
ok, remap ECU, replace ignitin switch, replace whole engine block..
man i dont think, ask any mechanic how he will solve it...
Old 06-20-2007, 11:27   #11 (permalink)
Member: 524232
Thanks Meter: 7
thats no good for helping bro.
Old 06-20-2007, 11:59   #12 (permalink)
..::Mr_Fone::..'s Avatar
Member: 364745
Thanks Meter: 719
Smile
hi m8t try this solution maybe your problem solve.
..::Mr Fone::..
Old 06-20-2007, 21:09   #13 (permalink)
puneet14884's Avatar
Member: 399779
Thanks Meter: 125
rehot or replace FDK..............all fine 99%...post result
Old 08-01-2007, 19:24   #14 (permalink)
RAMSUL's Avatar
Member: 112275
Thanks Meter: 34
help me, my 3100 signal drop after 2day, i am change haggar, fdk same problem. help give me good solution
Old 08-01-2007, 22:22   #15 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
change crystal near hager ic....tested !
nokia 3100 signal problem saqi160 Nokia Hardware & Hardware Repair 0 01-24-2009 11:08
nokia 3100 signal problem saqi160 Nokia Hardware & Hardware Repair 1 01-23-2009 08:16
Nokia 3100 No signal floky Nokia Hardware & Hardware Repair 5 07-24-2007 13:18
nokia 3100 no signal what is the probleme.... faisi Nokia Hardware & Hardware Repair 4 07-24-2007 13:16
Nokia 3100 some time full signal azeekhel Nokia Hardware & Hardware Repair 4 09-29-2006 00:44
Page generated in 0.26232 seconds with 10 queries
