Old 10-15-2008, 12:54   #1 (permalink)
Rajan chhetri's Avatar
Member: 799195
Sonork: all gsm cdma tool is best
Thanks Meter: 116
nokia 3110 contact service problem
I have 3110 contact service problem.phone made in hungary I already flash with hwk suite V_2.0.8 with latest flash file but faces this problem contact service what can i do for solution.please.......... give me solution
The Following 5 Users Say Thank You to Rajan chhetri For This Useful Post:
Old 10-15-2008, 13:24   #2 (permalink)
madho's Avatar
Member: 647592
Thanks Meter: 191
first check ur imei if it is ok then write tis pm and do factory setting ur set will be ok
The Following 18 Users Say Thank You to madho For This Useful Post:
Old 10-15-2008, 14:36   #3 (permalink)
RATHNAMOBILESS's Avatar
Member: 581178
Thanks Meter: 438
Arrow
use jaf
flash letest version
use unlock
problem not solve ?
100% cpu problem.........
The Following User Says Thank You to RATHNAMOBILESS For This Useful Post:
Old 10-15-2008, 15:16   #4 (permalink)
Dave.W's Avatar
Member: 7653
Thanks Meter: 823
And if problem is hardware??
Best solution is to run self tests and find root of the Contact Service.
The Following 2 Users Say Thank You to Dave.W For This Useful Post:
Old 10-16-2008, 07:02   #5 (permalink)
Member: 799195
Thanks Meter: 116
problem not solved again flash with new version and write this pm file but again this problem contact service any idea for this problem please share solution
The Following User Says Thank You to Rajan chhetri For This Useful Post:
Old 10-16-2008, 07:10   #6 (permalink)
shakeeldawach's Avatar
Member: 471955
Thanks Meter: 201
brother use good pm and use mt box SX4 AUTH SERVERS 100% OK
Shakeel Hussain
Dawachh
The Following 2 Users Say Thank You to shakeeldawach For This Useful Post:
Old 10-16-2008, 07:18   #7 (permalink)
mcclinic's Avatar
Member: 593876
Thanks Meter: 302
Its set not dct4 it is a bb5 so
Originally Posted by rathnamobiless View Post
use jaf
use unlock
problem not solve ?
unlock option of jaf activate only dct4 no bb5
The Following User Says Thank You to mcclinic For This Useful Post:
Old 10-16-2008, 07:23   #8 (permalink)
vertex777's Avatar
Member: 746552
Sonork: 100.1594844
Thanks Meter: 110
plz examine others condition such as......
Hi. bro If imei is ok your phone. then you can fash it update flash file and use good pm after this action you can use sx4 auth. otherwaise your problem is still you can write rpl. may be your problem is solved. But if have problem is still being and it takes restart. you can may confirm that CPU fault your phone.
The Following User Says Thank You to vertex777 For This Useful Post:
Old 10-16-2008, 07:32   #9 (permalink)
sam unlocker's Avatar
Member: 14632
Thanks Meter: 32
in 90% of cases in dct3 contact services due to cobba problem change it and all be ok
The Following User Says Thank You to sam unlocker For This Useful Post:
Old 10-16-2008, 07:52   #10 (permalink)
mcclinic's Avatar
Member: 593876
Thanks Meter: 302
Try to change charging ic
Originally Posted by rajan chhetri View Post
i have 3110 contact service problem.phone made in hungary i already flash with hwk suite v_2.0.8 with latest flash file but faces this problem contact service what can i do for solution.please.......... Give me solution
try to change ic may be solved
Old 10-16-2008, 08:14   #11 (permalink)
Member: 799195
Thanks Meter: 116
hear is my phone logs please give me solution
MCU SW : V 06.02 03-03-08 RM-237 (c) Nokia.
PPM SW : V 06.02 03-03-08 RM-237 (c) Nokia. MR
Prd.Code: 0514950
Bpr.Code: 0542523
Prod.Sn : 7F0821634
HW Vers : 2000
EM RETU : 32
EM TAHVO: 53
RFIC Ver: 17211721
DSP Vers: ICPR61_08w09
IMEI : 356975-01-290228-7
SL Serv : SIMLOCK SERVER VERSION 63
SL Conf : FFF-FF-FFFFFFFFFFF
SL Stat : FFFFFFFFFFFFFFFF
SL Count: 00 01
Provider: Not Found
The Following 2 Users Say Thank You to Rajan chhetri For This Useful Post:
Old 10-16-2008, 08:50   #12 (permalink)
alhaddare's Avatar
Member: 24239
Thanks Meter: 35
RPL injection needed
The Following User Says Thank You to alhaddare For This Useful Post:
Old 10-16-2008, 08:59   #13 (permalink)
.::AZEEM::.'s Avatar
Member: 336212
Sonork: 100.1585000
Thanks Meter: 4,912
Red face
its not dct3 its 3110 bb5
The Following User Says Thank You to .::AZEEM::. For This Useful Post:
Old 10-16-2008, 09:01   #14 (permalink)
Member: 336212
Sonork: 100.1585000
Thanks Meter: 4,912
Prd.Code: 0514950
Bpr.Code: 0542523
Prod.Sn : 7F0821634
HW Vers : 2000
EM RETU : 32
EM TAHVO: 53
RFIC Ver: 17211721
SL Count: 00 01
Provider: Not Found
u need Buy rpl and wright it problam slov
Old 10-16-2008, 09:08   #15 (permalink)
EJAZGUL's Avatar
Member: 638481
Sonork: 100.1601053
Thanks Meter: 749
Salaam!
Bro
just write rpl
& ur prob solve
thx
ejazgul
The Following User Says Thank You to EJAZGUL For This Useful Post:
nokia 3110 contact service problem Rajan chhetri Nokia Hardware & Hardware Repair 19 04-20-2011 14:03
Nokia 3110 Contact Service Problem Weller Nokia Hardware & Hardware Repair 5 01-09-2010 06:58
Nokia 3110 contact service solution sms-india Nokia Hardware & Hardware Repair 1 12-11-2009 08:37
nokia 3110 contact services ravi mobile Nokia Base Band 5 ( BB-5 ) 2 09-18-2009 08:22
Page generated in 0.30348 seconds with 10 queries
