nokia 3110 flashing problem help me plz its show me that rocessing file: rm237__07.21.mcusw RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM1 ID: 00000232 EM2 ID: 00000353 PUBLIC ID: 275001089B8C8B560E179AF1B0D999B66A2D7073 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F rap3gv3_2nd.fg: [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel ] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 RAP3Gv3_algo.fg: [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS ID: C0E691EA16A7593A9BB28832D7312A39F7ED668D Programming MCU ... rm237__07.21.mcusw: [BB5,BB5 ALGORITHM] size: 14.48 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Total erase size: 16.37 MB CMT NOR area [00000000-000006BF] erased in 0.891 s CMT NOR area [000006C0-0001FFFF] erased in 1.765 s CMT NOR area [00020000-0007FFFF] erased in 3.813 s CMT NOR area [00080000-000DFFFF] erased in 1.672 s CMT NOR area [00100000-001FFFFF] erased in 1.563 s CMT NOR area [00200000-0031FFFF] erased in 3.172 s CMT NOR area [00320000-0105FFFF] erased in 4.188 s CMT NOR area [01060000-01067FFF] erased in 1.718 s CMT NOR area [01068000-0107FFFF] erased in 1.672 s Flash programming ... Valid PAPUB key found, CMT PAPUBKEYS, RAP Certificate 66 v2 written. Error chk C7012D0103CD000010000000F1 RX2 not responded, please check BSI, cable/pinout ! Error while programming [00] at 0x00240400, Result: 0010 Flashing terminated with error(s) in 45.938 s RX Buffer: C7012D0103CD000010000000F172 on mx key i can change cable but its cant salve... any body help me? |
Help me plz.......................... |
Hello Masters, I have same .... Plz :confused: |
flash with usb cable by mx key or jaf pkey |
Sometime its your Cable Fault and Sometime Need Some Hardware. But 1st try flash with usb cable with jaf or mxkey. |
first Check fbus cable 2nd flash with update ver 7.30 if no ok then try to usb |
bro try it on hwk uer pro will be slove |
bro i think your cable is 5pin so you use 7pin cable and 7.30 file version and flash with ufs/atf try and post. |
Brother 1st flash UFS with skip erasing, if it show BLK error then click on yes, yes ,yes untill the process is completed 100%. Then flash it MX-key with usb cable. I hope ur problem 100% solved. I tested many time.............. |
check your cable or its hardware problem. |
bro u just flash it with JAF it will be ok its common prob in 3110c with hwk and mx key it will be solved by JAF |
