Old 09-13-2012, 16:47   #1 (permalink)
Member: 1671566
Sonork: 100.1645138
Thanks Meter: 21
nokia 3110c phone restricted
how to fix this problem..plz help team members. i flash full but same problem.....what to do........
Old 09-13-2012, 16:50   #2 (permalink)
kaller1's Avatar
Member: 1761928
Sonork: 100.1626169
Thanks Meter: 804
unlock phone, and problem solved...
Old 09-13-2012, 17:02   #3 (permalink)
rahulgsm7's Avatar
Member: 1810350
Sonork: 8888888
Thanks Meter: 9
reset all factory setings ...........
Old 09-13-2012, 17:06   #4 (permalink)
GAURAV-MOBILE's Avatar
Member: 1798882
Thanks Meter: 155
update simlock bro..............
100 % tested many time.
The Following User Says Thank You to GAURAV-MOBILE For This Useful Post:
Old 09-13-2012, 17:11   #5 (permalink)
Member: 1579398
Sonork: 1991
Thanks Meter: 22
which box use bro use atf dairect unlock sl 2 bro ur solution
Old 09-13-2012, 18:04   #6 (permalink)
bobaly's Avatar
Member: 1291612
Sonork: 100.1625587
Thanks Meter: 98
Repair SD key & update Sl Data.
Your Problem 101% Soul.................
Old 09-13-2012, 18:12   #7 (permalink)
way2unlock's Avatar
Member: 582682
Sonork: 100.1607124
Thanks Meter: 136
Bro use mx.atf.cyclone.ub.jaf zulia crack.best
Unlock only done.
Old 09-13-2012, 18:15   #8 (permalink)
rakib_sheak's Avatar
Member: 1201843
Thanks Meter: 487
Old 09-13-2012, 18:22   #9 (permalink)
Member: 1809324
Sonork: 100.1621044
Thanks Meter: 4
use mx key,atf,cycolne
in mxkey try it
go in service > Imei&security tick Make simlock RPL then Update Sp lock (mx-key)
The Following User Says Thank You to rkbizsecurelab For This Useful Post:
Old 09-13-2012, 18:57   #10 (permalink)
Dipankor-ctg's Avatar
Member: 1541551
Sonork: +965 99095810
Thanks Meter: 4,698
@ Roshan Chauhan
Now ATF Box
See Work here
Bro
Dipankor-ctg(gsmasha)
Old 09-13-2012, 19:07   #11 (permalink)
Member: 200634
Thanks Meter: 41
by ATF box do sim lock repair
Old 09-13-2012, 19:19   #12 (permalink)
snmobilecenter's Avatar
Member: 983663
Sonork: 100.1623270
Thanks Meter: 551
@Roshan chauhan
its enough ans for you ..
next time post in correct place also try search...
thanks
br
snmobilecenter
Old 09-13-2012, 19:22   #13 (permalink)
vikasgoyals786's Avatar
Member: 1732891
Sonork: 100.1616947
Thanks Meter: 445
read here your solution
update your simlock data with mx box your problem will be solved 100%
Old 09-13-2012, 19:27   #14 (permalink)
Member: 963505
Thanks Meter: 50
fenixkey rpl unlock 100% solve
other post is helpful & ok solution ..........bro
Old 09-15-2012, 10:01   #15 (permalink)
Member: 1671566
Sonork: 100.1645138
Thanks Meter: 21
Thanx bro its work
..............................now phone is working fine
Page generated in 0.21796 seconds with 8 queries
