nokia 3200 I have a nokia 3200, when the phone is switched on it comes but nothing displayed on the screen just light on the background...anyone have a solution for it? |
1-check lcd connector. 2-try another lcd. 3-try software. |
already tried all 3 ideas but it still not resolved the problem |
hi Quote:
new nokia all hardware solution searc 3200 led IC |
still not found my answer |
hi all 2 Attachment(s) Quote:
step 1 : after u put on the phone are u able to switch it off with on/off switch or u have to switch it off by removingb the battery step 2 : if u r able to put the phone off with on/off switch then try to resolder the display connector also check the display connector lines as per the circuit diagram. step 3 : in case if u r not able to power off the phone with on/off switch then 100% software flash ur phone mcu + ppm parts. u should b ok |
thanks guys i will have a go tommorow |
have same probleme, I test LCD of my 3200 on 3100, and LCde work perfectly, and I put LCd of my 3100 on 3200 = same probleme ? some one have idea or solution for this probleme. br, JAVA Good. |
if your fone can call and recieve but no display remove the 2 resistors below the power switch(on either side of antenna pad) and link the track,it worked for me let me know if it helps any1 else |
