11-03-2001, 20:04 | #2 (permalink) |
Junior Member Join Date: Aug 2001
Member: 5749 Status: Offline Thanks Meter: 1 | heh ....<br />if phone displays "Not Charging "<br />open it ... between bat connectors u will see <br />thermistor ... measure resistance btw Btemp and <br />positive connector of bat ... it should be <br />30-50 kohm ... if not .. then solder thin wire <br />btw bottom pad of thermistor and GND <br />or remove the bottom (positive) connector plastic <br />and resolder it good .... <img src="smile.gif" border="0"> <br />byez also u can check resistors and cap's <br />as shoun in 3210 service manual ! |
The Following User Says Thank You to MOTGSM For This Useful Post: |
nokia 3210 not charging | barthosyn | Nokia Hardware & Hardware Repair | 2 | 06-10-2008 03:51 |
Nokia 3210 not charging | sadgsm | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 11-18-2003 15:07 |
nokia 3210 not charge (ONLY when power ON) | redlion3210 | Nokia Hardware & Hardware Repair | 7 | 09-21-2003 11:26 |
3210 not charging with car-charge | fiZ | Nokia Hardware & Hardware Repair | 4 | 10-18-2002 14:52 |
3210 not charging | ambot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 05-06-2001 21:41 |
