Old 05-22-2006, 22:16   #1 (permalink)
kaligola's Avatar
Member: 239318
Thanks Meter: 51
8800 problem
the board has been cutted due a fall from 4th floor, now does not charge or headphone funcions, but the rest works, if i short contracts where are cutted? any ideas? pleas thanks.
br
Old 05-23-2006, 09:06   #2 (permalink)
Member: 275032
I guess you can reconnect the lines that are damaged...Just be carefull though, make sure its the right connection or you might be making the situation worse... good luck
Old 05-23-2006, 22:30   #3 (permalink)
kaligola's Avatar
Member: 239318
Thanks Meter: 51
thanks, but will be difficult 4 me, tought short the two lanes without the small resistor, guess is a resistor, because the little piece turns on the back of keybord support.
8800 problem with speaker robinhood UFS2 + UFS3-Tornadoflasher 4 07-11-2008 15:14
8800 problem after flash ddhorn MT-BOX 14 06-09-2006 18:58
Page generated in 0.12076 seconds with 9 queries
