03-17-2005, 11:52 | #1 (permalink) |
Freak Poster Join Date: Jul 2002 Age: 54
Member: 13844 Status: Offline Thanks Meter: 1 | Nokia 3220 no network |
The Following User Says Thank You to Albinas For This Useful Post: |
03-23-2005, 14:21 | #3 (permalink) |
No Life Poster Join Date: Jul 2004 Location: BANDA ACEH INDONESIA
Member: 74519 Status: Offline Thanks Meter: 79 | here solution: 1. (griffin) make flash MCU+PPM+UCP files, after finish do not unplug cable, now send pm to phone after pm sent, do unlock, now unplug cable and power on phone with simcard inserted if not slove go to point 2 2. rehot with some of good flux mjolner and component around it, PA and component around it so Antenna swich, let air heater make it move and PA you must press down carefully when tin of weak, after rehot finish, let pcb going cold and now try to power on with simcard inside, I bealive your phone will be OK |
05-04-2006, 08:49 | #6 (permalink) |
Freak Poster Join Date: May 2005 Location: Philippines Age: 42
Member: 144777 Status: Offline Sonork: 100.111515 Thanks Meter: 100 | same prob. with me mga bosing..... i tried also all posible i.c related for signal but their is simple procedure to fix that prob. just try this! eraseflash first flash mcu,ppm, w/ cnt mcu v.5.10 ppm 5.10x cnt images_x and after flashing complete WRITE pm before UI settings it works 100% |
07-08-2010, 15:54 | #8 (permalink) |
Registered User Join Date: Dec 2009 Location: HABARADUWA - Sri Lanka Age: 39
Member: 1179630 Status: Offline Sonork: 100.1644820 Thanks Meter: 80 | change Power Amp. It is only one solution |
The Following User Says Thank You to wasangaama For This Useful Post: |
3220 no network help me,no rx no tx ,help me | shivam4you | Nokia Hardware & Hardware Repair | 1 | 03-09-2009 07:37 |
3220 no network and insert sim card | JeAn-cLeM | Nokia Hardware & Hardware Repair | 5 | 11-27-2008 13:04 |
3220 no network | genoma20 | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 09-17-2005 11:01 |
3220 no network..but searching well manually | manish1234 | Nokia Hardware & Hardware Repair | 5 | 08-26-2005 16:07 |
