11-16-2008, 15:04 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Pakistan & Bahrain Age: 37
Member: 617073 Status: Offline Sonork: 100.1611349 Thanks Meter: 316 | nokia 3220 strange problem MCU ID: 0x2142 FLASH ID0: 882E0020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05.50 19-12-05 RH-37 (c) Nokia. HW version: 6260 PCI version: UEM version: 400 UPP version: 8514 RFIC version: 0205 DSP version: P05w06.v26_SLM LCD version: AMAZON PPM version: V 05.50 19-12-05 RH-37 (c) Nokia. G Production serial number: 2HE356723 Product code: 0520475 Module code: 0202178 Basic production code: 0516128 Flash code: Order number: Product specific data: Long production SN: ATO: 2????????????????????????????????????????????????? Default SN type: 2????????????????????????????????????????????????? IMEI plain: 357623005813603 IMEI spare to net: 3A 75 26 03 50 18 63 00 IMEI SV to net: 33 75 26 03 50 18 63 10 F7 Master Code: 6617070314 Failed reading simlock data... Phone type: RH-37, Software version: 05.50, Language Pack: G User code: 12345 Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RH-37.ini Saved INI not found, loading INI list... Checking path: C:\Program Files\Nokia\Phoenix\Products\\ Searching for default location of ini... Checking path: \Products\\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Done! Powering the phone... Unlocking... IMEI: 357623005813603 Failed! Aborting! Asic 00 nokia 3220 problem when call end than mobile restart otherwise mobile working fine plz help me |
3220 strange problem | Wasim bye | Universalbox | 1 | 05-16-2008 11:48 |
3220 strange problem | Sandeep_$tomar | Nokia Hardware & Hardware Repair | 3 | 01-03-2008 13:19 |
3220 strange problem | aryan_ | Nokia Hardware & Hardware Repair | 17 | 06-21-2007 09:48 |
3220 Strange problem | sonkar | UFS2 + UFS3-Tornadoflasher | 1 | 03-15-2006 23:14 |
