NOKIA 3220 white screen with battery please this phone when you insert the battery or in UFS, it shows white screen. When you press check in ufs or info, it only goes on and off in the screen without any display. Any solution mates. |
this falt is moissher lite heat camra ic cpu and power is and 100% set ok |
7610-6670-3230-6600 blank screen solution!! WORKING %100000 3230 6670 7610 blank screen solution!! first of all this problem happend after wrong flash OR WHEN FIRMWARE WILL BE DAMAGED or u recive the phone with this problem and normal flashing with mcu and ppm did not help to repair this problem so do next 1- with ufs box start to erase manual this adress start: 00000000 end: 00FFFFFF start: 02000000 end: 02FFFFFF start: 04000000 end: 047FFFFF this 3 adress will erase the 3 flash's and u will not lost ur phone imei 2- with ufs again erase start: 00010000 end: 0000FFFF start: 02000000 end: 00FFFFFF start: 02FC0000 end: 0286FFFF start: 02A00000 end: 0000FFFF 3- flash ur phone with latest firmware 4- write full pm to ur phone 5- unlock and format user area ASHRAF |
pls flashing fr jaf pls |
try flash with jaf sir.. |
i change N2400 in display ic now the phone work again |
pls flashing with jaf ........... |
