Old 09-27-2007, 05:47   #1 (permalink)
Member: 172811
Thanks Meter: 135
n70 automatic power on-off!
n70 turn on automaticly when i put the battery ,, after second i see that it turn off like i press the power botton,!when it on i see like i press the power botton and go to profile select and sometimes turn off and on by itself...!
i remove the power botton ,R4406 and change the RETU . the same problem exist!!!!hen i remove the RETU and check for empidense on the power switchwith the ohm-meter , there is nothig ,..!!
any idea?
Old 09-27-2007, 06:55   #2 (permalink)
Member: 595260
remove power botton and see what you see ? this is my idea
Old 09-27-2007, 22:13   #3 (permalink)
Member: 172811
Thanks Meter: 135
my idea is you did not see what i wrote.!
Old 10-20-2007, 22:18   #4 (permalink)
Member: 372160
Thanks Meter: 11
masters help me
i resive like this phon any solatin for me
Old 10-20-2007, 23:20   #5 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
hi,check power button and make manul format whats the result send me.............
Old 10-21-2007, 14:31   #6 (permalink)
reji's Avatar
Member: 227127
Thanks Meter: 241
any idea?
bro,
the power switch track from RETU doesnt goes directly to the switch, its connected through the EMIF filter Z4403. so check this filter also.
Old 10-23-2007, 19:40   #7 (permalink)
Member: 172811
Thanks Meter: 135
Originally Posted by reji View Post
bro,
thank you for your reply , but as i recheck the the line i see (and you see)that the power switch is connected directly to the RETU .!!!!there is no connections between z4403 and the switch line!!!!
Old 10-23-2007, 19:50   #8 (permalink)
reji's Avatar
Member: 227127
Thanks Meter: 241
yes bro, in schematics the switch is connected directly to RETU.
but in the board its connected through Z4403. if u want check, remove that IC and check the voltage on the power switch.
Old 10-23-2007, 20:20   #9 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
bro,
yes according to schem its direct goes to retu . not involve Z4402 or Z4403.
rashid
Old 11-03-2007, 11:53   #10 (permalink)
Member: 172811
Thanks Meter: 135
thank you very much REJI. problem solved. true i just remove z4403 and see 2 pins under connected, i just clean and reinstall , the phone work fine!!!!!
strange! how we can depend on schematics!!!or its another hardware virsion im working on!
Old 12-11-2007, 11:30   #11 (permalink)
mr_loverman's Avatar
Member: 87722
Thanks Meter: 112
i have same problem. can you please upload picture of z4403. i cant find it on board
Old 09-10-2008, 12:42   #12 (permalink)
Member: 116572
Thanks Meter: 22
Z4403 is the display filter sir
Old 09-10-2008, 13:36   #13 (permalink)
Member: 223257
Thanks Meter: 12
Chang ic LCD (Right) near Real tim Clock
6101 power on off automatic!!!!! hassan siddiqui Nokia Hardware & Hardware Repair 0 10-07-2009 18:32
3110c automatic power gets off imran_4_u Nokia Hardware & Hardware Repair 1 03-14-2009 03:28
3110cn6300 automatic power gets off imran_4_u Nokia Hardware & Hardware Repair 8 02-14-2009 10:16
6210 power-on-off-on-off Safrane Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 07-20-2002 15:55
N3210 powers ON-OFF automatically when is on charger!?! MaRiN Nokia Hardware & Hardware Repair 1 12-24-2001 00:31
Page generated in 0.25680 seconds with 10 queries
