02-20-2010, 03:19 | #1 (permalink) |
Registered User Join Date: Aug 2009 Location: mumbai
Member: 1098397 Status: Offline Thanks Meter: 80 | nokia 3230 phone start-up failed help me |
The Following User Says Thank You to palav For This Useful Post: |
02-20-2010, 03:54 | #2 (permalink) |
Member: 1098397 Status: Offline Thanks Meter: 80 | chk Getting MCU ID MCU ID: 0x1081 FLASH ID0: 007E0001 <=> SPANSION -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 007E0001 <=> SPANSION -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 277E0001 <=> SPANSION -> Type not in database Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... info Powering the phone... Reading... MCU SW version: V 5.0614.0 22-03-06 RM-51 (c)NMP HW version: 0580 PCI version: UEM version: 144 UPP version: 4225 RFIC version: 0205 DSP version: B0439U_05w33 PPM version: V 5.0614.0 22-03-06 RM-51 (c)NMP.05 Production serial number: DNA032914 Product code: 0522253 Module code: 0202511 Basic production code: 0519957 Flash code: Order number: Product specific data: Long production SN: ATO: h????????????????????????????????????????????????? Default SN type: h????????????????????????????????????????????????? IMEI plain: 357099002940535 IMEI spare to net: 3A 75 90 09 20 49 50 03 IMEI SV to net: 33 75 90 09 20 49 50 13 F2 PDC: 4E 54 54 4A 50 12 34 56 Master Code: 0157056376 Phone type: RM-51, Software version: 5.0614.0, Language Pack: 05 User code: 12345 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-51.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0522253 Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-51\ Scanning for ini files... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-51\RM51PE506140.C1 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-51\RM51PE506140.33 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Done! |
02-20-2010, 13:58 | #9 (permalink) | |
No Life Poster Join Date: Mar 2009 Location: Pakistan Bahawalpur
Member: 986273 Status: Offline Thanks Meter: 397 | Quote:
all will b fine | |
3230 Phone Start up Fail Repaired By Typhoon | Chennairam | Typhoon Dongle | 8 | 08-28-2011 16:23 |
n96 contact retailler-phone start up failed--help me for SX4 | zone2 | Nokia Base Band 5 ( BB-5 ) | 11 | 05-11-2010 09:15 |
Nokia N96 phone start-up failed. help me | rafiqcell | Nokia Base Band 5 ( BB-5 ) | 6 | 01-16-2010 06:38 |
nokia 7610 phone start-up failed help me pls | palav | Nokia Hardware & Hardware Repair | 15 | 12-11-2009 07:58 |
N96 After unlock phone start up fail help me | chamin | Nokia Base Band 5 ( BB-5 ) | 9 | 06-26-2009 12:30 |
