04-07-2009, 15:54 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Faisalabad, Pakistan Age: 41
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | Nokia 3250 Keypad 7,8,9 Kind regards, Vicky |
04-07-2009, 19:00 | #3 (permalink) |
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | I already said that i have try to change main board which work perfect on other so it mean that ic is good and working all parts I have try to change instead of flex so one track is missing which will cover by jumper but not know where jumper so tell solution about jumper not ic etc. Waiting for your kind response. Kind regards, Vicky |
06-25-2010, 06:11 | #4 (permalink) |
Junior Member Join Date: Jun 2010
Member: 1332033 Status: Offline Thanks Meter: 0 | Hi Guys I'm Having the same problem with Nokia 3250 , Recently I have installed a S60v5 app. in it which led to immidiate crash of phone when ever I switch on. So I have restarted it by holding Call+*+3 n power key. It was restared n woking fine but I experience some problem in using 1, 2, n 3 keys. But It works if you slide it to side by side or press hardly. But from yesterday 1, 2, 3 is not working atall. Also I have opened the down to see how the keys are n open the white stricker wher some silver like metal r sticked to it. then like small circles. I thought that It must be the problem of silvr cicles so i've replaced n clean then wid other keys by It doesn't work. Please reply n help Adarsh |
6210 keypad 7-8-9 not work | smartpb | Nokia Hardware & Hardware Repair | 10 | 03-05-2013 21:11 |
nokia 5310, keypad 7. 8.9.problem.? | gsm st | Nokia Hardware & Hardware Repair | 19 | 07-19-2010 15:31 |
D520 keypads 7,8,9, left, don't work, need help! | vanhh | Samsung Hardware Repair | 1 | 08-20-2008 15:16 |
6600 keypad 7,8,9,number problem | toolsveera | Nokia Hardware & Hardware Repair | 3 | 09-22-2007 23:52 |
C-25 keypad 7,8,9 not work | tuppy | Siemens Hardware Repair Area | 0 | 12-03-2003 09:03 |
