nokia 3310 i have nokia 3310 which is automaticaly switch on and off either on external supply or battry |
hi man in this CASE check SHORT" to ground pad ON POWER switch or Short bsi to ground line :) |
@ Mohammed I've solved this problem by Shorting the BSI line to Ground. But the problem is that, it does not charge battery. Only battery symbol comes and disappere within 1 second while putting the charger. Have any solution for the problem ? Thanks. |
1 Attachment(s) Quote:
oto power---------------------------------------------------------- |
check v-202 change it or remove component |
