Old 12-09-2006, 08:29   #1 (permalink)
Member: 232344
Thanks Meter: 7
nokia 3310
Phone is dead when try to switch on . Only one led of Lcd blinking.\
Old 12-11-2006, 09:39   #2 (permalink)
Member: 304723
change power ic (ccont)
Old 12-11-2006, 10:01   #3 (permalink)
Lhick's Avatar
Member: 333359
Thanks Meter: 91
Might be a wet unit, Clean board, Check lines
Old 12-12-2006, 06:13   #4 (permalink)
Allunlockingsource's Avatar
Member: 333439
Sonork: 100.1589101
Thanks Meter: 623
plz change ui ic maybe your problem is slove
Old 12-12-2006, 06:37   #5 (permalink)
Crazy Poster
Member: 304762
CHAnge ui ic. chack positive lines of led.or get a supply from keypad led.try to make jumper from keypad led to lcd led....
Old 12-12-2006, 07:09   #6 (permalink)
Member: 248245
Thanks Meter: 85
Check positive Line according to attach picture, if ok check the following
The voltage at C404,C202,C226,C227,C228 is 3.6V if No Failure in Vbatt line Check X203, R220 if yes Voltagae on R224 is 3.6v if no Defective 201 or PCB if yes voltage at C316=2.8v and C243=2.8v if No WDDISX=0 when pwr switch is press if No Check Power switch Check WDDISX line PWR Switch-> R402 if yes Defective CCont N201, and post result.
Old 12-12-2006, 11:07   #7 (permalink)
Member: 232344
Thanks Meter: 7
what i am asking? not about Led's i am worry about dead problem of set.
Old 12-17-2006, 06:23   #8 (permalink)
sallupat's Avatar
Member: 138982
Thanks Meter: 138
try to chnage the battery & also battery connector & try to switch on with out SIm card
salim
Old 12-17-2006, 06:28   #9 (permalink)
blu angel's Avatar
Member: 168090
Thanks Meter: 92
The problem of your phone is Vbatt...
Jumper the positive terminal to any of the negative side of the LCD bulb...
Regards
blu angel
Old 12-17-2006, 07:19   #10 (permalink)
jothi737's Avatar
Member: 369539
Sonork: 1584109
Thanks Meter: 32
change flash ram &chech power suply then flash..................
Is it the on/off switch is same in between nokia 6600 and nokia 3310 yccomc Nokia Hardware & Hardware Repair 2 09-30-2005 03:33
Wanted x1 nokia 3310 board & x1 nokia 3410 board cameraman Wanted Products 4 09-12-2004 16:11
NOKIA 3310 AMTX99 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 03-26-2001 17:01
There it is ! The new Nokia 3310 Tevoxx Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-01-2000 13:44
NOKIA 3310 Tevoxx Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-31-2000 14:05
Page generated in 0.22348 seconds with 10 queries
