11-14-2006, 09:34 | #1 (permalink) |
Freak Poster Join Date: May 2006
Member: 283474 Status: Offline Thanks Meter: 41 | Nokia 3310 dead |
11-14-2006, 11:06 | #2 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | Hi Friend use full flash means first eares then write mcu+ppm+pmm then write imei full default ui setting Good Luck post result |
11-21-2006, 08:32 | #4 (permalink) |
Junior Member Join Date: Nov 2006
Member: 390052 Status: Offline Thanks Meter: 0 | first boot oky means the cpu is oky that means there is a hope to solve the broblem 1-tray first to clean the phone correctly 2-full erase 3-mcu+ppm+ui.option 4-this step is very important..which is rebuild imie otherwise the phone will go on-of by itselfe |
11-21-2006, 13:43 | #5 (permalink) |
No Life Poster Join Date: Jul 2006 Location: IBADAN, OYO STATE, NIGERIA
Member: 319112 Status: Offline Thanks Meter: 164 | Make Sure The Battery And Cable Contacts As Well As Their Interfaces Are Clean And That There Is Good Contact Between Cable And Phone And Try Again. If There Is No Success, Then You May Rework The Power Ic {ccont}, The Flash Ram And The Cpu And Then Try Again. If All These Do Not Help Then Try Resolder The 4 Contacts Of The Real Clock Crystal And Try Again. |
11-23-2006, 19:09 | #7 (permalink) |
Freak Poster Join Date: Sep 2005 Location: united kingdom Age: 49
Member: 182216 Status: Offline Thanks Meter: 24 | i have encountered that problem before i found that the tool i used ,be it ufs,twister,tornado,could have a virus or a bug,re install the flasher firmware,trust me it will work....as long as the flasher reads the phone the eeprom is ok...you mite have removed a virus from a dct4 phone or bb5 phone this could cause the dc3 firmware in the flasher not to work or has a bug,re install the flasher firmware... |
NOKIA 3310 Dead | Shahrukh | Nokia Hardware & Hardware Repair | 24 | 10-03-2003 00:21 |
Nokia 3310 Dead | taiyeadekeye | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-26-2003 18:17 |
Nokia 3310 dead after flashing wrong flash? | AFR | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-25-2003 18:47 |
Nokia 3310 dead? | spako | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-2002 19:26 |
Nokia 3310 dead need flasher help | jim_pam | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 07-23-2001 09:52 |
