02-11-2005, 13:26 | #1 (permalink) |
Freak Poster Join Date: Dec 2004 Age: 41
Member: 97043 Status: Offline Thanks Meter: 29 | nokia 3310 net pro....... |
02-17-2005, 20:22 | #10 (permalink) |
Freak Poster Join Date: Nov 2003
Member: 44625 Status: Offline Thanks Meter: 36 | @segun, U can do reballing with ur rework station, reballing paste and the correct stencils. Do a search on the forum for old posts on reballing. There's one that gives step by step instructions. Good luck! |
02-17-2005, 20:27 | #11 (permalink) |
Member: 44625 Status: Offline Thanks Meter: 36 | @ZetMen, If u could post meanings of netmonitor for network problems, it'd be most helpful. DOn't forget to mention which menu. Is it possible to use it with DCT4 phones, and if yes, how? |
02-17-2005, 20:51 | #12 (permalink) |
Junior Member Join Date: Feb 2005 Location: nigeria Age: 48
Member: 116593 Status: Offline Thanks Meter: 0 | hello I have problem with nokia 2100 if I call the phone go off by him salf and I change the pf but the problem stil same thing plz help [email protected] |
02-17-2005, 20:54 | #13 (permalink) |
Freak Poster Join Date: Aug 2004 Location: f dewana Age: 43
Member: 79056 Status: Offline Thanks Meter: 149 | Here is a no network way of diagnostic: Run a test with Eeprom tools 3.1 and 4.0 this gives a point next its important if the test is good and no network, I mean phone cant even see it next steps: Put SIM card, power on, dial a service number and put phone close to a turned on radio /close to the antena/ if there is a conection with network U will here "puk, puk, puk, puk/ if U dont hear it this solves the problem in most cases 1. Reheat CCONT-> check phone 2.Reheat COBBA -> check phone 3.Reheat HAGAR-> check phone If there is network but cant make a call this is PA- U will not hear puk puk puk on radio test.. Tip..HAGAR is a DSP processor the phone is registering with network with it But in nokia phones /DCT3/ problems are mostly around CCONT and COBBA Good luck! ReGarD HaiDouR |
02-24-2005, 09:38 | #15 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Cyprus Age: 42
Member: 15149 Status: Offline Thanks Meter: 61 | netmonitor test 01 first you have chananel then Rxlevel then TX Power if you have activate netmonitor put 01 test and put on keyboard * for1-2 sek you will be have help what is what. If you dont have rx that check hagar and vco, and first try to change diplexer (antena switch) or do line in 900 mHz and check that you have rx if you have and you cannot call change PA if not try to rehot coba,ccont and then if not call change coba and flash,faid i it should be work. |
2760 net pro | chandrakumari | Nokia Hardware & Hardware Repair | 1 | 12-09-2009 19:11 |
3310 net problem | manir | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 01-06-2005 08:32 |
Activating Net Monitor on Nokia 3310 | hactic | GSM Programming & Reverse Engineering | 1 | 07-23-2003 01:56 |
Nokia 6110 Net Monitor | gsmxc | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-04-2000 21:28 |
Nokia 6110 Net Monitor | Frickles | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-26-1999 13:05 |
