Old 09-02-2006, 16:13   #1 (permalink)
Crazy Poster
Member: 298038
nokia 3310 nothing happens when charger connected
Hello im getting problem with a nokia 3310. when i connect the charger nothing happens. i checked fuse and coil, all correct. but when i checked connector pads for charger they were short circuited, i tried to look on the pcb to see whether anything was touching, but all were fine, any idea? maybe if i got the charger line schema, that could solve my problem. please help [email protected]
Old 09-02-2006, 21:02   #2 (permalink)
Member: 223959
Thanks Meter: 8
may be ur phone is water damaged clean pcb effectively then try charging
post ur result
Old 09-02-2006, 21:10   #3 (permalink)
Crazy Poster
Member: 341699
post ur result
also you can check the socket and change it if not work
Old 09-03-2006, 12:13   #4 (permalink)
adampurhawks's Avatar
Member: 258154
Thanks Meter: 319
Get UR Phone Working Perfect
Hi Mate
Just Check ur phone like in pic attached and replace these parts
Tested by me on hundreds of Phones
Regards
Adampur Hawks
Old 09-03-2006, 12:38   #5 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,395
chek the attachment and do like this.......
Old 09-04-2006, 13:29   #6 (permalink)
Crazy Poster
Member: 298038
Already tried these things,
already tried these things, fuse and coils changed, p.c.b cleanned, but still the problem is the same. any idea.. i wonder why these two pads are short circuited
Old 09-04-2006, 14:52   #7 (permalink)
Member: 258154
Thanks Meter: 319
Hi
If still not ok check if supply from Charging Socket is coming to fuse pad or not..if still not ok then change the Charging IC
Regards
Adampur Hawks
Nothing happens when conncting BB while unlocking dinci5 BlackBerry (RIM) 2 08-25-2009 18:45
7250i nothing happen when charged anjeli Nokia Hardware & Hardware Repair 4 07-11-2008 17:34
3310 switch on only when charger connected kprajeesh4u Nokia Hardware & Hardware Repair 1 05-28-2007 09:55
nothing happens when press keys s500i "H"2 Trident/AGERE Platform 0 07-17-2006 19:07
Furious Dongle II...Nothing happens when trying to run program tical FuriouS II 20 04-10-2005 17:07
Page generated in 0.20275 seconds with 10 queries
