Nokia 3310 problem Hello every1 I have this problem with my nokia 3310 have signal all the time (3-4 bars) but when I call it fast change network chanells (still changing 3 chanels )and phone off from 3-4 bars of battery thx for reply |
how old is you'r battery ? try with an new one. Make an complete test with an GSM tester to be sure that you'r RF part is working properly or not... |
Hi, Flash the phone by full flash (include Eeprom). If problem still exit, check battery, battery pin, battery pin contact pad(PCB), P.A & CCONT. Best regards Henry14 |
if you flash the phone with new eep data you can forgot about TX/RX/batt calibration... bye-bye. Wrong advice... Do not do that ! |
hi change pa if not then change flash it can't be repaired by programming and if still it fails, ccount must be changed. you will get your phone repaired. but do the process in chained way. |
Thx all for replies I now that isnīt sw problem I change PA and reflow CCONT and now is all OK Thx |
