nokia 3310 shows charging but not charging hi, i got nokia 3310 shows charging but not charging and discahrge fas a new charged battery. i change CCONT AND CHARGER IC. STILL THE SAME. |
change chaps |
@sergiomes.. Chaps=Charger IC !!!! @crossings.. Check resistebelity between +Ve and -Ve power leads it must be usually higher than 1Mohm, if there is eny resistance U have to finde the cause,U can devide the phone into 3 isolated areas by the raising of L513, and L201. And mesure each sector indevidually. |
Medz thanks!!! |
If none of these help, and the phone is charging without a charger, Check connect between R200 and c200/c201. If the are not connected, shortcut them with some wire... Scorp |
dear pl. check the track from R200 to R204 & pl. check batt. (+) pos.to R200 these are all same track if u no make a track <first >? after that try to change a n-200 |
