Old 10-31-2003, 10:31   #1 (permalink)
crossings's Avatar
Member: 9897
Thanks Meter: 7
nokia 3310 shows charging but not charging
hi, i got nokia 3310 shows charging but not charging and discahrge fas a new charged battery. i change CCONT AND CHARGER IC. STILL THE SAME.
Old 11-01-2003, 01:17   #2 (permalink)
sergioems's Avatar
Member: 9502
Thanks Meter: 9
change chaps
Old 11-01-2003, 01:40   #3 (permalink)
Member: 39601
Thanks Meter: 13
@sergiomes..
Chaps=Charger IC !!!!
@crossings..
Check resistebelity between +Ve and -Ve power leads it must be
usually higher than 1Mohm, if there is eny resistance U have to
finde the cause,U can devide the phone into 3 isolated areas by
the raising of L513, and L201. And mesure each sector indevidually.
Old 11-01-2003, 09:09   #4 (permalink)
crossings's Avatar
Member: 9897
Thanks Meter: 7
Medz thanks!!!
Old 11-05-2003, 01:13   #5 (permalink)
Member: 22627
If none of these help, and the phone is charging without a charger, Check connect between R200 and c200/c201. If the are not connected, shortcut them with some wire...
Scorp
Old 11-07-2003, 13:23   #6 (permalink)
Member: 43545
Thanks Meter: 7
dear pl.
check the track from R200 to R204 & pl. check batt. (+) pos.to R200 these are all same track if u no make a track <first >?
after that try to change a n-200
Nokia N72 showing charging but not charge moscotech Nokia Hardware & Hardware Repair 9 05-18-2010 15:46
A800 show charging but not charge NELIX VLSI, Conexant, Skyworks and Old Models 12 08-22-2004 18:00
Alcatel BE3 show charging but not charges SVH Alcatel TCL Hardware Repair 1 08-02-2003 23:26
3310 show charging but not charge!!! florinmar Nokia Hardware & Hardware Repair 3 05-28-2003 09:25
3210 shows charging, but not charge actually. sat Nokia Hardware & Hardware Repair 6 11-02-2001 01:28
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.12490 seconds with 8 queries
