Old 11-24-2013, 18:17   #1 (permalink)
Cheater -Don't Deal with him-
Member: 1707492
Thanks Meter: 606
nokia 500 &700 not start when i insert sim solution-100% new& JUMPAR
nokia 500 not start when i insert sim smee to nokia 700 .
with out sim phone start ok
but with sim start with nokia logo then off
i can flash with latest version but problem still same
and finely solution ..see my photo ..and do it 100% working it no way to others solution ..
pa sky 77432-21 C7 C6-01 nokia 500 303 700 701 N8 N9
File Type: jpg 1463120_620872911308449_228338644_n.jpg (25.9 KB, 3535 views)
File Type: jpg 1391433_620873154641758_1642640469_n.jpg (174.2 KB, 3836 views)
The Following 2 Users Say Thank You to MATELECOM1 For This Useful Post:
Old 11-27-2013, 08:02   #2 (permalink)
shinod's Avatar
Member: 55363
Thanks Meter: 146
is this tested solution?????
The Following User Says Thank You to shinod For This Useful Post:
Old 11-27-2013, 08:13   #3 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
so many nokia phone have this problems
when power on with sim phone go to trun off
problem go to pa problem
just change pm
this jumber is right but not work perfectly
full singnal area work only this phone also we faced error in connection problem
100%solution change pa
The Following 4 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 11-27-2013, 08:41   #4 (permalink)
Member: 390858
Thanks Meter: 29
is the solution tested guys
The Following User Says Thank You to chiefonline For This Useful Post:
Old 11-27-2013, 08:55   #5 (permalink)
.::Gsm_Srilanka::.'s Avatar
Member: 1133072
Thanks Meter: 505
correct say by SHIJILFONOTLY
it work but only high signal aria, in my work shop i never do P/A jumper for any phone.
The Following User Says Thank You to .::Gsm_Srilanka::. For This Useful Post:
Old 11-28-2013, 08:31   #6 (permalink)
Member: 1707492
Thanks Meter: 606
[QUOTE=SHIJILFONOTLY;9909751]so many nokia phone have this problems
just change pm
100%solution change pa[/QUOTE
bo i know .. jumpar ..ara not work 100% ..what i say ... change pa
you don t have pa after jumpar ... ..you know this about ..why not shear in forum ..... i m shear ..
The Following User Says Thank You to MATELECOM1 For This Useful Post:
Old 12-20-2013, 18:31   #7 (permalink)
Hussain_Mobile's Avatar
Member: 681758
Sonork: 100.1676160
Thanks Meter: 347
just change pm
yes you say right
:::Hussain:::
The Following 2 Users Say Thank You to Hussain_Mobile For This Useful Post:
Old 05-26-2014, 10:52   #8 (permalink)
Member: 2193354
hi could u pls tell how to change pa..
where it is available
The Following User Says Thank You to drssamuelraj For This Useful Post:
Old 07-28-2014, 11:53   #9 (permalink)
Member: 1707492
Thanks Meter: 606
lol go market its avelavel in market
Old 08-21-2014, 17:23   #10 (permalink)
rasid310's Avatar
Member: 1467586
Thanks Meter: 80
bangali bhai if rimove coil what abut network
Old 11-09-2014, 15:24   #11 (permalink)
.::PankajMobileWorld::.'s Avatar
Member: 1910515
Thanks Meter: 289
MATELECOM1
Thanks bro for guide me.
very help full report.
My problem solved.
Old 11-10-2014, 04:40   #12 (permalink)
Member: 2212215
Change pa is the most right solution tested 6 mobile Nokia 303, Nokia 500, Tested
Also can be 700, 900 not yet tested
Old 11-10-2014, 06:40   #13 (permalink)
Member: 1234585
Sonork: gazi_321
Thanks Meter: 37
700 500 work good ...................
Old 11-10-2014, 06:47   #14 (permalink)
usmano abdullah's Avatar
Member: 1206600
Sonork: 100.1670311
Thanks Meter: 11
Tested and it work but no network
Old 11-10-2014, 13:52   #15 (permalink)
mahzra azra's Avatar
Member: 1722956
Sonork: mybestfriend.adeel
Thanks Meter: 305
others solution ..
bro this solution is not only for these modle .this fault for every model of nokia.
when set working fine without sim card and after insert sim card when just network comes set power off .
this fault you can chek without sim card.only make 112 call if set powerd off it means pfo damage. simple.
Page generated in 0.22403 seconds with 9 queries
