06-17-2001, 20:32 | #5 (permalink) |
Freak Poster Join Date: Jan 2001 Location: I.C., R.P.
Member: 3165 Status: Offline Thanks Meter: 0 | Try to use nokiatool. Choose Device Data and UI Settings and then press Apply SFS. The problem might be on your eeprom data after the contact service. If problem still persists, then try viewing it as a hardware problem. Regards, aCe |
06-17-2001, 20:59 | #6 (permalink) |
No Life Poster Join Date: Dec 2000 Location: Slovakia, Brezno
Member: 2721 Status: Offline Thanks Meter: 23 | Now i find out, that IMEI in eeprom was changed. First 2 number are changet to 00, i repair it, no effect. And power consuption is higher then normal. |
06-26-2001, 12:23 | #8 (permalink) | |
Freak Poster Join Date: Feb 2001 Location: Cj,Ro,Eu
Member: 3262 Status: Offline Thanks Meter: 1 | Quote:
You can try to change the BGY 251 IF it's that PF.There is near de antena conector,under the ecranage. My best regards cosmo | |
06-26-2001, 15:47 | #9 (permalink) | |
Freak Poster Join Date: Apr 2001 Location: INDIA
Member: 4223 Status: Offline Thanks Meter: 4 | Quote:
Hello Ars. As u says that your phone comes to u with Contact Service and u've repaired your phone. I think your phone has got software problem. Why don't u try to change the flash,EEPROm and Cobba to cunfirm weather it is hardware or software problem. If it is software problem then no success by changing all the stuffs. So try that way. Good Luck | |
06-26-2001, 16:57 | #10 (permalink) |
Member: 3165 Status: Offline Thanks Meter: 0 | Guys, its an identity problem. Ars said that the IMEI has changed. So whether you change all those hardware, you will still get no signal coz the phone will simply just fail to register to the network. TO Ars, did you use nokiatool to check the IMEI? If yes, was it the Original IMEI (below) or the real IMEI (above)? If it is above, then phone needs to be reprogrammed. Try any Nokia Service Center for this or somebody who has the Dejan 1.04. Your eeprom needs to be recreated/recalculated. Regards, aCe |
2x 5110 no signal | Black-Axe | Nokia Hardware & Hardware Repair | 1 | 10-11-2007 02:44 |
Mr.Willy please help 5110 no signal | uwenk98 | Nokia Hardware & Hardware Repair | 6 | 01-13-2003 13:28 |
5110 no signal | OrbiTel | Nokia Hardware & Hardware Repair | 6 | 09-27-2002 07:23 |
5110 no signal at all! | josaic | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-07-2002 06:33 |
5110 no signal on orange | storm101 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 07-14-2002 02:21 |
