01-13-2010, 14:34 | #1 (permalink) |
No Life Poster Join Date: Nov 2008
Member: 899774 Status: Offline Sonork: 100.1586303 Thanks Meter: 449 | nokia 5130 auto power on then hang with nokia when i put battery phone automatic powered and stuck with nokia i tried to flash but phone not booted any idea to fix this problem? |
The Following 3 Users Say Thank You to rumenshom For This Useful Post: |
01-13-2010, 14:55 | #3 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Bangladesh/UAE
Member: 1108551 Status: Offline Sonork: Jerry Thanks Meter: 153 | 1st give M/B a bath with thinner .. and Put it with soldering pest under 100w Light for hour.. Then wash it and try to flash with latest File... |
The Following 2 Users Say Thank You to jerrymamun2009 For This Useful Post: |
01-13-2010, 19:50 | #6 (permalink) |
No Life Poster Join Date: Apr 2009 Location: MobiCare, Mh-50, India
Member: 1019814 Status: Offline Thanks Meter: 653 | Bro 1st U need to solve its auto-poweron problem. Its on switch track goes through keypad ic. so check whether there is any sign of liquid damage? get keypad ics heated well or change them, Once auto poweron gets solved , try flash phone with latest version..... Good luck |
The Following 3 Users Say Thank You to k_abhi For This Useful Post: |
01-14-2010, 07:56 | #7 (permalink) | |
Member: 899774 Status: Offline Sonork: 100.1586303 Thanks Meter: 449 | Quote:
thanks for understanding topic | |
The Following User Says Thank You to rumenshom For This Useful Post: |
01-15-2010, 01:50 | #9 (permalink) |
Junior Member Join Date: Apr 2009
Member: 1009652 Status: Offline Thanks Meter: 2 | Hello, I have a nokia 5310 it just says NOKIA and restarts. I want to restore the software with JAF + PKEY THOMAS, but the phone is not placed in local mode. What part can I change to fix that and you can restore it? If I can help with an image, the better. .:GSM-SERVER:. |
07-29-2010, 07:18 | #12 (permalink) |
Freak Poster Join Date: Oct 2009 Location: *ChiTtaGoNg KiNgS*
Member: 1134660 Status: Offline Sonork: 100.1593764 Thanks Meter: 280 | No erras this phone bcoz it is a SL3 phone you can' bacup restore & can't be simlock data repair, so beceareful no erras just flash letest ver with 5130 XpressMusic RM-495 CareDP 18.12 i hope yore phone repair completly done. |
07-29-2010, 08:09 | #13 (permalink) |
Junior Member Join Date: Jul 2006 Location: Bariga lagos
Member: 309729 Status: Offline Thanks Meter: 0 | guy dont erase your phone cos if you do it will write contact service just download latest file from www.shrak-moble.com then flash it will be okay.i try it and work... |
08-16-2010, 04:40 | #14 (permalink) |
No Life Poster Join Date: Oct 2007 Location: nigeria
Member: 601591 Status: Offline Thanks Meter: 86 | bros this is uem problem,remove the cover the seal with careful and use fuel to service ur pcb very well now rehot it a little your problem solved 100000000000% i have done many and the problem is water. pls dont flash ur set my pple anybody can consult me i have many solution but i dont hv any diagram unless you can understand my explanation. thanks |
nokia 6500s auto power on | haider | Nokia Hardware & Hardware Repair | 4 | 11-27-2008 07:32 |
auto power on,key hang complete sol.for ZTC ZT6668 | abhi01 | Chinese Models & Cloned Phones | 1 | 10-25-2008 06:52 |
V3 Auto Power on then on/off button not work | .:Towhid:. | Motorola Hardware Repair | 2 | 08-01-2007 12:09 |
very usefull solution for Nokia 3310 auto power ON/off | GSM SNIPER | Nokia Hardware & Hardware Repair | 4 | 07-03-2004 20:51 |
6210-301 auto power on and hangs sometimes | bre786 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-08-2001 07:48 |
