05-28-2011, 17:37 | #36 (permalink) |
Freak Poster Join Date: May 2004 Location: Silent Mode Age: 39
Member: 65656 Status: Offline Thanks Meter: 91 | write block error=> check flash chips. Done write and cant localmode try see totaly time at flash. Same with normal phone? Check ur version if same. Higher. |
08-25-2011, 11:34 | #38 (permalink) |
Insane Poster Join Date: Jan 2009
Member: 936481 Status: Offline Sonork: saeedbaco Thanks Meter: 11 | Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.97 13-09-10 RM-495 (c) Nokia Imei plain: 35422303450175-9 Product Code: 0577793 Battery voltage: 4280 mV, current: 79 mA Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 354223034501759 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN pls help |
09-10-2011, 19:32 | #41 (permalink) |
Freak Poster Join Date: Mar 2010
Member: 1259614 Status: Offline Thanks Meter: 57 | Phone type: RM-495 (Nokia 5130c-2) SW version: V 07.97 13-09-10 RM-495 (c) Nokia Imei plain: ok Product code: 0571981 Battery voltage: 4604 mV, current: 60 mA Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 0k Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
09-15-2011, 19:57 | #44 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Hwk is the BEST NOKIA TOOL
Member: 735523 Status: Offline Sonork: 100.1591830 Thanks Meter: 262 | i have same problem the log hear Selected Highest installed version: 07.97 Mcu rm495__07.97.mcusw Ppm rm495__07.97.ppm_mena_a1 Content rm495__07.97.image_mena_a1_red MemoryCardContent rm495__07.97_sd_seap.fpsimage Using Tx2 Data line. BB5 PM back Phone is in: Phone is not responding! Processing File: rm495__07.97.mcusw Boot... CONNECT PHONE to USB and Power ON phone! Pooling for phone... \\?\nmwcd#vid_0421&pid_0106&if_oth#6&333ea993&1&00 #{4f919102-4adf-11d5-882d-00b0d02fe381} Sending ULO code Sending UPDAPP code Sending PASUBTOC code Pooling for device removal... Device removed Pooling for ADL device... \\?\nmwcd#vid_0421&pid_0105&if_oth#6&2d7afc25&0&00 #{4f919102-4adf-11d5-882d-00b0d02fe381} CMT Certificates NOT SUPPORTED Erase[63.63 MB]... erasing RAP [00000000 to 000006BF] erasing RAP [000006C0 to 0001FFFF] erasing RAP [00040000 to 000BFFFF] erasing RAP [000C0000 to 0013FFFF] erasing RAP [00140000 to 0137FFFF] erasing RAP [01380000 to 0151FFFF] erasing RAP [01DC0000 to 0215FFFF] erasing RAP [02160000 to 03FBFFFF] erasing RAP [01520000 to 01DBFFFF] in 279.82s Flash[18.20 MB]...in 80.00s * * Processed file in 376.82 seconds Processing File: rm495__07.97.image_mena_a1_red Boot... Pooling for ADL device... \\?\nmwcd#vid_0421&pid_0105&if_oth#6&2d7afc25&0&00 #{4f919102-4adf-11d5-882d-00b0d02fe381} Erase[0.00 MB]... in 0.19s Flash[10.26 MB]...in 43.57s * * Processed file in 43.95 seconds Processing File: rm495__07.97.ppm_mena_a1 Boot... Pooling for ADL device... \\?\nmwcd#vid_0421&pid_0105&if_oth#6&2d7afc25&0&00 #{4f919102-4adf-11d5-882d-00b0d02fe381} Erase[0.00 MB]... in 0.16s Flash[6.07 MB]...in 26.86s * * Processed file in 27.16 seconds Restarting device... Pooling for device removal... Device disconnected. * * * Phone flashing done in 7:59 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! Dynamic camera configuration... |
09-15-2011, 20:04 | #45 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,595 | Quote:
