12-30-2010, 15:03 | #1 (permalink) |
Registered User Join Date: Jan 2008 Location: Where never ends.
Member: 669673 Status: Offline Thanks Meter: 301 | Nokia 5130 only vibrate...........solution? I have nokia 5130 which have only vibrate when switch on, i flashed with 7.97 version with mxkey and hwk by fbus cable flashing was seccuses but ui setting failed. i also flash usb flashing with mx key there was also succuses flashing but ui setting failed. Have any solution ? i need it. Thanks. |
The Following User Says Thank You to ravi mobile For This Useful Post: |
12-31-2010, 14:29 | #6 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Talk to *** and He Will Listen
Member: 532761 Status: Offline Sonork: 100-1592994 Thanks Meter: 1,104 | i think there is a common problem in bb5 phones i encounter that problem 10 is to 9 repairable via change ape br venuno |
The Following User Says Thank You to venuno For This Useful Post: |
04-13-2011, 08:16 | #10 (permalink) |
Freak Poster Join Date: Jul 2010 Location: india gujrat Age: 47
Member: 1338815 Status: Offline Sonork: DD ELECTRONICS Thanks Meter: 58 | mr. ravi bb5 & ui seting??? it,s a not dct 4 phone bb5 phone mast only flashing you tryed ui option your simdata & pm demej in same time so u not use ui option try this tips 1st chek your pcb is water demej??? 2.. chek lcd 3. chek yor softwar log see simlock data is ok or not?? 4. updete hwc ,,ccc, data 5..write pm only .1&309 6 check or cheng thvo 7.not ok ?? check rap ic |
09-17-2011, 04:55 | #12 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: CYCLONE IS THE BEST TOOL FOR N
Member: 614801 Status: Offline Thanks Meter: 134 | Quote:
most of the the time ape,change bt i.c is 30% only,simlock damaged is not connected,for that problem sir | |
