Old 01-26-2009, 19:39   #1 (permalink)
Member: 256231
Thanks Meter: 24
nokia 6300 keypad solution
i have nokia 6300 which none keypad don't work. Please can i do?
The Following User Says Thank You to Romu For This Useful Post:
Old 01-27-2009, 03:25   #2 (permalink)
Member: 371944
you must change ic keypad
Old 01-27-2009, 08:23   #3 (permalink)
samirov-gsm's Avatar
Member: 759168
Thanks Meter: 12,866
change ic keypad....................
Old 01-27-2009, 09:44   #4 (permalink)
Member: 256231
Thanks Meter: 24
Where is ic keypad on the board? thanks
Old 01-27-2009, 09:49   #5 (permalink)
Member: 643285
Thanks Meter: 11
ic keypad change it
enjoy
Old 01-27-2009, 10:34   #6 (permalink)
Member: 45716
Thanks Meter: 38
ic is next to the simreader the glass ic its the same as 3110classic keypad ic.
Old 03-28-2009, 09:48   #7 (permalink)
muzaffar shah g's Avatar
Member: 557894
Sonork: no
Thanks Meter: 35
The Following 6 Users Say Thank You to muzaffar shah g For This Useful Post:
Old 07-30-2010, 17:54   #8 (permalink)
Member: 875748
i changed the keypad ic but still the keys are not working i think its another problem pls help! the problem starts after phone was drop and hit the ground,i need your help very urgent pls!
Old 10-09-2010, 12:54   #9 (permalink)
Registered User
Member: 818659
Thanks Meter: 13
i change keypad ic any key not press what is the solution please help
Old 10-09-2010, 13:28   #10 (permalink)
jaymercado48's Avatar
Member: 1382153
Sonork: 100.1594354
Thanks Meter: 60
change the keypad ic again maybe the ic is faulty change a new one............
Old 06-26-2011, 13:58   #11 (permalink)
Member: 1042248
Sonork: 100.1603905
Thanks Meter: 28
i chnge keypad ic more then five pls give perfect solution
Old 06-26-2011, 14:14   #12 (permalink)
hand2hand's Avatar
Member: 1476841
Thanks Meter: 201
brother,
1. change keypad ic
2. remove side volume key up and down
prob, still
3,then slow heat in cpu
4, problem still change cpu
Old 05-16-2013, 07:58   #13 (permalink)
..:: Devil_king ::..'s Avatar
Member: 696623
Sonork: 100.1601050
Thanks Meter: 526
nokia 6300 no keypad ic solution by jumper???
Nokia N81 Keypad solution 100% Tested solution Here gsmhosting Nokia Hardware & Hardware Repair 29 09-25-2012 09:11
6300 Keypad Solution camso Nokia Hardware & Hardware Repair 18 04-30-2011 16:49
nokia 6300 keypad problem wegeras Nokia Hardware & Hardware Repair 14 07-12-2010 15:17
Nokia 6300 restart solution needed.. tutu1982 Nokia Hardware & Hardware Repair 8 08-09-2008 14:20
nokia 6300 keypads "4, 5, 6 " Fonefingz Nokia Hardware & Hardware Repair 5 05-14-2008 03:04
Page generated in 0.22027 seconds with 10 queries
