11-14-2012, 13:58 | #5 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Get Closer with Mobile Age: 44
Member: 228358 Status: Offline Thanks Meter: 32 | 1. remove all small chip top side of battery contact. 2. change BTEMP resiter. 3. Check charging contacts resistance ( short circuited or not) 4. If short circuited remove fuse and make jumper from +ve of charging contact to after fuse. dont forget to make a small insulation on the +ve pad of charging pads on pCB |
11-14-2012, 16:31 | #11 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2011 Location: APPEL
Member: 1707492 Status: Offline Thanks Meter: 606 | hello friends look my post you sore u r ic 100% ok ?? ok so chik u r phone mexky scan SECURITY_TEST failed!?? SUPERDONGLE_KEY invalid ???? show SECURITY_TEST failed! ...and repere ..u r phone 100% ok |
11-15-2012, 08:15 | #13 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Saudi Arabia
Member: 615730 Status: Offline Thanks Meter: 256 | Brother its fault of Voltage so first u must change the good working R2070 if same then change good working Betty IC. Remember good working ic post result. |
