Old 01-31-2008, 12:48   #1 (permalink)
Member: 157878
Thanks Meter: 6
2610 keypad problem
i have a nokia 2610 that fell into water. i have sericed it but the menu botton is not working. The board is reading but no response. Any solution please??
Old 02-09-2008, 21:10   #2 (permalink)
Member: 669218
Thanks Meter: 11
change the key pad ic with most carefully ur problem will solve thanx
Old 02-09-2008, 21:21   #3 (permalink)
F@RUK S's Avatar
Member: 51153
Sonork: 100.113241
Thanks Meter: 3,682
1st try to rehot ic
br...
allGSMunlock
faruk...
Old 02-09-2008, 21:32   #4 (permalink)
mobilagy's Avatar
Member: 217479
Thanks Meter: 267
I prefer to replace keypad filter since it's liquid damage case, cause liquid will affect sooner or later on filter's pins, only if it was held so fast after liquid accident so reflowing with flux will be enough .
Old 02-21-2009, 11:44   #5 (permalink)
ghazishah's Avatar
Member: 754267
Thanks Meter: 116
hi dear i hv nokia 2610 its some keys are not 4,5,6 and up button not working i hv changed is key pad ic but still same prop plz send me any good solution urgent
THANKS in advance
Old 02-23-2009, 06:42   #6 (permalink)
Member: 882164
chisssssssssssssssssssssssssssssssssssss very helpful in my repearing lab
Old 02-23-2009, 06:46   #7 (permalink)
shahidsattar's Avatar
Member: 388454
Thanks Meter: 1,101
clean the whole board with ctc. then rehot or replace keypad ic. if problem still not solved then rehot or reball cpu
The Following User Says Thank You to shahidsattar For This Useful Post:
Old 11-04-2009, 10:23   #8 (permalink)
Member: 1114126
Thanks Meter: 2
change kepad ic that is only the perfect solution for it i think soo
The Following User Says Thank You to faizatechnicals For This Useful Post:
Old 07-06-2012, 08:48   #9 (permalink)
nurchad.msl's Avatar
Member: 1757930
Sonork: 100-1620660
Thanks Meter: 95
nokia 2610 menu key notworking 100000% solution
try this
Old 04-08-2013, 10:04   #10 (permalink)
Member: 1813549
Sonork: DJ PARVEZ
Thanks Meter: 2
same problem 2610 123 key not work
6700c keypad problem luyanda Nokia Hardware & Hardware Repair 20 04-09-2014 10:16
2610 keypad crystal hany elsaghir f Nokia Hardware & Hardware Repair 11 04-11-2008 10:18
2610 keypad jumper bkr_33 Nokia Hardware & Hardware Repair 2 10-04-2007 10:40
2610 strange keypad problem celluniversal Nokia Hardware & Hardware Repair 0 09-08-2007 15:33
Page generated in 0.17783 seconds with 9 queries
