nokia 5233 need urgent help by expert i have 5233 set,set is ok in coming and out going ok. but no light on display, i changed light ic 10 to 15 times but no light. i think this is not a light ic fault. expert xplan me all digrame for light. thanks in advace. |
http://mobifonerepair.com/wp-content...play-light.jpg Quote:
i done it already but light ic is not making volt. tell me,what i do????? |
1 Attachment(s) what about display? did u seen anything on lcd? if not replace d marked ic then check. also post result |
i made jumper and changed Z2450 but not good result. i m unable to see garafic. more help. |
help me fast. where is xpert. |
try to resold or replace lcd connector then check. |
but light ic is not making any volt. i changed many light ic. |
this phone light ic is diffrent then anothers get it from another 5233 or 5800 ur problem will b solved... |
two time ic from same board i used but same . help more. and a another nokia 5233 set was ok only user code ,i flash with old ver. flash file, it gone only vibrat mode. i download latest ver RM-625_51.9.002_prd.core.C00 but same in condition. help for this too. |
1 Attachment(s) after getting signal from lcd , light ic enable means supply voltage to glow led. thst's why I ask u to resold or replace lcd connector , or double check d lcd esd filter . here I upload another picture for understand. (N2301 is d light ic) please post result. |
Also check what scsarcar say from capacitor C2445 to LCD connector pin3 if line ok not broke. Post Result |
5233 Lcd Light 5233 Light problem i tryed all jumpers & light ic. then tryed with betty now its working fine :) |
near lcd conector display ic remove ind make jumper ur problem solve 100000% dont forget thanks |
check lcd ic . sounds strange but it will work |
