06-20-2008, 13:23 | #1 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | LED Driver IC jumper for 5300 . . . ? I have 5300 phone. Which has only disply light is not work. But keypad Light is working Fine. So i need LED driver IC jumper. OR please tell me what is the solution for this set. Thankx in advance. |
06-20-2008, 16:55 | #2 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | have you check lcd flex cable ? if yes then check B to B connector or resold , also check lcd with working one by the way led driver ic can't be bypass because it's a voltage booster ic input voltage 3.6 & output voltage near about 14.5 , so you have to change that ic post result |
07-12-2008, 20:18 | #3 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
did u find it..? i need it too.but i think ur pb was flex... i need led driver jumper cause of damaged point under the led driver... | |
07-13-2008, 07:32 | #7 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | Quote:
check this ic n2401 light track for display is gone from this ic ......check this ic .....in some pcb this ic is not placed....there is a sinngle resistance so check wheteher it has ic or resistance in ur ocb and check with other pcb......this will help u....i have solve my problem of display light from this ic,....if ur keyboard lights are ok then ur light ic is ok...........so check it and post result... | |
07-13-2008, 13:45 | #8 (permalink) |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | thanx... yes i know this is led driver ic.. but i need led driver jumper... cause one way is broken,damaged under led driver ic.. |
The Following User Says Thank You to LoveLess For This Useful Post: |
07-13-2008, 13:58 | #9 (permalink) | |
Insane Poster Join Date: Sep 2005 Age: 42
Member: 180806 Status: Offline Thanks Meter: 2 | Quote:
it is sure that led driver ic is leg like in your drawing, i think its a sim ic or mic for 5300/5200.. because the led driver ic is same leg as n70, 7360, and 1112.. | |
08-04-2008, 11:24 | #11 (permalink) | |
No Life Poster Join Date: Apr 2003 Location: pakistan Age: 44
Member: 27289 Status: Offline Thanks Meter: 24 | Quote:
New Keypad Ic Jumper For 6120,6300,N76.... | Jeffyoh88 | Nokia Hardware & Hardware Repair | 6 | 10-31-2012 08:14 |
New hot ringer ic jumper for 1110,1600,2310,2610,6030etc. | gopalhot | Nokia Hardware & Hardware Repair | 43 | 05-12-2010 07:11 |
5610 LCD driver ic jumper ways, anyone? | winxp_sp2 | Nokia Base Band 5 ( BB-5 ) | 10 | 10-19-2009 08:44 |
Boot Ic Jumpers For Nokia 7610-6600-n70-n-gage | venusmobilecare | Nokia Hardware & Hardware Repair | 9 | 11-21-2008 22:56 |
ic jumper for display and camera motorola v3 | tuli | Motorola Hardware Repair | 4 | 02-06-2008 02:12 |
