Old 06-26-2008, 11:21   #1 (permalink)
asimbutt's Avatar
Member: 394146
Thanks Meter: 56
5310 charger not suported
need solution ......................................
Old 06-26-2008, 11:50   #2 (permalink)
Sagitarious's Avatar
Member: 615730
Thanks Meter: 256
Need Urgent solution ...............
Old 06-26-2008, 12:14   #3 (permalink)
Amit Tank's Avatar
Member: 219831
Thanks Meter: 104
here
http:///vbb/showth...=5310+charging
SEARCH BUTTON IS WORK WELL
Amit Tank
The Following User Says Thank You to Amit Tank For This Useful Post:
Old 06-26-2008, 13:59   #4 (permalink)
Member: 615730
Thanks Meter: 256
i check all those thing but not work .any other solution .
Old 06-26-2008, 14:16   #5 (permalink)
Amit Tank's Avatar
Member: 219831
Thanks Meter: 104
TESTED SOLUTION IS CHANGE R2047 47K ..............GOOD LUCK
THEN POST RESULT
Amit Tank
Old 06-26-2008, 15:20   #6 (permalink)
Member: 615730
Thanks Meter: 256
bro i did not find it plzzzzzzzzzzzz kind give me pic of that .
Old 06-26-2008, 15:39   #7 (permalink)
Amit Tank's Avatar
Member: 219831
Thanks Meter: 104
sorry dear that is R2071 ,
thats my mistake
u can find easily this in schematic
Amit Tank
Old 06-26-2008, 16:01   #8 (permalink)
Member: 615730
Thanks Meter: 256
bro i change it but same ..................
Old 06-26-2008, 16:11   #9 (permalink)
Amit Tank's Avatar
Member: 219831
Thanks Meter: 104
ok
now reball AVILMA ic , ( if posible change )
post result
Amit Tank
Old 06-26-2008, 17:23   #10 (permalink)
Member: 615730
Thanks Meter: 256
bro i try it but same ....... another thing when the phone is switch of it show charging perfect .an when it on it show charger not supported.... need solution ........
Old 06-27-2008, 10:50   #11 (permalink)
Member: 615730
Thanks Meter: 256
need solution..........................................
Old 06-27-2008, 12:04   #12 (permalink)
..::Mr_Fone::..'s Avatar
Member: 364745
Thanks Meter: 719
here is br all 5310 problem in one diagram i hope your problem solved ...
Best Regard.
IKRAM BUTT
The Following 3 Users Say Thank You to ..::Mr_Fone::.. For This Useful Post:
Old 06-27-2008, 13:24   #13 (permalink)
Member: 766602
Sonork: hitech
Just Change that Duplicate batary............
Insert New Batary, It must be similar to Original Batary,
Which is came fom NOKIA.
Taha's all............
I Think Problem Is may be Solve
Old 10-16-2008, 18:47   #14 (permalink)
turktwister's Avatar
Member: 84208
Thanks Meter: 25
i changed betty,avilma,make jumper and so on..
but still not solved
Old 10-16-2008, 18:58   #15 (permalink)
Member: 11726
Thanks Meter: 10
hi
just change Btemp resistor R2071
5310 sl3 not suported redouane2007 Universalbox 2 01-12-2010 11:42
5300 charger not suported Diamond02 Nokia Base Band 5 ( BB-5 ) 9 09-08-2009 02:02
7390 charger not suported Gozha Nokia Base Band 5 ( BB-5 ) 7 09-21-2008 13:07
nokia 6131 charger not suported muruganssv Nokia Hardware & Hardware Repair 3 02-02-2008 10:25
6300 charger not suported mhamad-198 Nokia Hardware & Hardware Repair 3 10-23-2007 13:15
Page generated in 0.25097 seconds with 10 queries
