03-10-2009, 12:20 | #2 (permalink) |
No Life Poster Join Date: Aug 2008 Location: india
Member: 843418 Status: Offline Thanks Meter: 740 | br. check shorting in 5310.. 1..remove this coil mark in (1)...if u want to check is light ic is short,..... 2..remove this coil mark in (2)..if u want to check ringer ic is short because rf ic also got +b volt from battery.... 3..remove this coil mark in (3)..if u want to check audio amplifier voltage maker ic n2101 is short because bluetooth ic also got +b volt from battery.... 4..remove this rf ic mark in (4)..if u want to check the shorting is remove because rf ic got +b from batery. it can be check only by removing this ic 5..remove this ic mark in (5)..if u want to check the shorting is removed..this ic also got +b it can be check only by removing this ic . 6..also check the blue tooth ic because it also got +b from batery it can be check only by removing this ic 7..at end remove avilma and betty ic... all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic .... [email protected] |
The Following User Says Thank You to biniesh_08 For This Useful Post: |
nokia 5310 dead after flashing | rana_jee | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 34 | 12-09-2013 08:41 |
nokia 5310 dead durring flash | gsm5378 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 03-17-2010 05:21 |
nokia 5310 dead by mxkey | sunny_luthras | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 06-21-2009 08:11 |
Please Help Nokia 5310 Dead | NIMESHFONOTLY | Nokia Hardware & Hardware Repair | 8 | 08-25-2008 14:00 |
Nokia 5310 After Flashing Dead | SAMESHP | Nokia Hardware & Hardware Repair | 6 | 08-23-2008 20:41 |
