Old 05-31-2011, 18:14   #16 (permalink)
Member: 197541
Thanks Meter: 28
Originally Posted by DD ELECTRONICS View Post
try this step
1, backup only rap
2, riset npc ccc,hwc & chak it phone is on??? phone is on so it,s a rpl problam & not on continu step
3 , full ereas flash
4 , flash with higar v, in usb cabal , & ristor only npc no full backup
5 , your phone find is local mode or test mode
6 ,, write pm rf ,bb
7,, riset manul in phone not softwar factary riset
your phone is ok
warning it,s a softwar problam so no hiting rap & falsh ic
how about simlock??? i see you need good teacher...
Old 06-16-2011, 14:52   #17 (permalink)
Member: 651892
Thanks Meter: 205
when u got the local mode simply backup your simlock data before erase.
Old 06-18-2011, 14:14   #18 (permalink)
Member: 622484
Thanks Meter: 5
any one solved this problem ? just [email protected]
Old 06-18-2011, 14:21   #19 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
Bro.try this solution.
http://forum.gsmhosting.com/vbb/f148...-here-1250036/
Old 06-18-2011, 14:59   #20 (permalink)
Member: 622484
Thanks Meter: 5
5230 only vibrate solution.........
check bsi print braek and apply jumper ...tested ..
Old 07-21-2011, 11:02   #21 (permalink)
Member: 66429
Thanks Meter: 2
Originally Posted by md jawad View Post
plz help any solution
try power on with charger
Old 07-29-2011, 09:11   #22 (permalink)
Malik Irfan85's Avatar
Member: 1484062
Sonork: 1610135
Thanks Meter: 218
Solution is here 5530 only vibrate. . .
1st you have mxkey
2nd Quick fix nd Bb5 SW Downgrade fix. . .
your problem is solved. . .
and dont say 4 thanks. . .
Br. Malik Irfan
Old 12-04-2011, 04:08   #23 (permalink)
tchinidor's Avatar
Member: 422574
Thanks Meter: 85
Originally Posted by Malik Irfan85 View Post
1st you have mxkey
Br. Malik Irfan
quick fix bb5 sw downgrade for the sl2 phones i think !!!!
Old 06-10-2012, 19:48   #24 (permalink)
Crazy Poster
Member: 935540
Thanks Meter: 20
Originally Posted by mahbubalfa View Post
Bro.Rehot rap ic.
hope your problem will be solve.
same problem after rehot rap ic
The Following User Says Thank You to loranss For This Useful Post:
Old 06-15-2012, 00:49   #25 (permalink)
Member: 601591
Thanks Meter: 86
check bsi line ........
Old 09-24-2012, 01:11   #26 (permalink)
Member: 1011014
Thanks Meter: 3
Hi ppl. Only vibration when pressing Nokia 5530 on/off button. I´ve been having the same problem. Sometimes phone vibrates when pressing the on/off button. But the screen keeps dark. If i connect it to usb to computer, i press and hold on/off button and it vibrates, but its not detected bu sistem. Sometimes i give it a short press and the usb insert sound sounds, but after a couple of seconds the unplug soud its heard.
Now, im using a USB cable, and my operative sistem its W7 Ultimate. When o procedd to flash everything goes well, till the phone disconects himself in the "pooling" time. The screen starts flashing the LCD wirhe various colors, then it ends, and UB Box comes up with error codes, saying that the flash didnt went well cause it couldnt get a connection with the phone, even if i prees on button and hear the connection sound. Do i have to use the F-Bus cable wich i dont have yet? Is there any other solutions?
The Following User Says Thank You to Blue699 For This Useful Post:
Old 09-24-2012, 08:30   #27 (permalink)
Member: 1810593
Thanks Meter: 3
Flash with same product code flash files
Asif India
Old 09-02-2013, 16:08   #28 (permalink)
Member: 2014334
use uno file to come back at local/Test mod. then flash with higher version.
Page generated in 0.19847 seconds with 9 queries
