Old 03-25-2012, 15:59   #1 (permalink)
rajibsaha's Avatar
Member: 717313
Sonork: 100.1611706
Thanks Meter: 35
Red face Nokia 5800 only vibrate .....
Nokia 5800 only vibrate , use search or try many other solution ...
but not sucess ...
Need tested solution plz ..........
plz help........
Old 03-25-2012, 16:11   #2 (permalink)
6622622's Avatar
Member: 1562066
Sonork: 100.1622824
Thanks Meter: 554
only software problem just do it brother & tell me if ur handset same condition then check your lcd jack
The Following User Says Thank You to 6622622 For This Useful Post:
Old 03-25-2012, 16:40   #3 (permalink)
srt6's Avatar
Member: 826522
Thanks Meter: 33
Originally Posted by rajibsaha View Post
nokia 5800 only vibrate , use search or try many other solution ...
But not sucess ...
Plz help........
if u tried alot of solutions but
no success 1 more solution is for
repairing this problem is just
change its upp as well as its flash ic.
The Following User Says Thank You to srt6 For This Useful Post:
Old 03-25-2012, 16:44   #4 (permalink)
akhtarmughal's Avatar
Member: 617073
Sonork: 100.1611349
Thanks Meter: 315
but not sucess ...
plz help........
try this and post result here
The Following User Says Thank You to akhtarmughal For This Useful Post:
Old 03-25-2012, 18:06   #5 (permalink)
sr8787's Avatar
Member: 788946
Sonork: 100.1682685
Thanks Meter: 490
Just rehot touch ic or change lcd ic. only vibrate problem solve many time with this method. reply result and log.
The Following User Says Thank You to sr8787 For This Useful Post:
Old 03-26-2012, 05:30   #6 (permalink)
rajibsaha's Avatar
Member: 717313
Sonork: 100.1611706
Thanks Meter: 35
thank,s all of them try to all but no sucess .............
plz help, other solution plz ........
Old 03-26-2012, 07:54   #7 (permalink)
Member: 617073
Sonork: 100.1611349
Thanks Meter: 315
ok bro flash latest version with UFS or JAf your problem solved
Old 03-26-2012, 08:27   #8 (permalink)
mahzra azra's Avatar
Member: 1722956
Sonork: mybestfriend.adeel
Thanks Meter: 304
download flash file from fire agent .
select indian flash file.
after it flash with this file if ur set is not making call.
ur problam will be solved sure.
if any problem my massenger id is_
[email protected]
The Following User Says Thank You to mahzra azra For This Useful Post:
Old 07-19-2012, 14:26   #9 (permalink)
6622622's Avatar
Member: 1562066
Sonork: 100.1622824
Thanks Meter: 554
today same problem with me but no solution no idea if have any body then post here plz
Old 11-08-2012, 06:35   #10 (permalink)
pooja_19's Avatar
Member: 326069
Thanks Meter: 18
Nokia 5800 5230 5233 5530 Power On Just Vibration 100% Tested Solution
Reading RPL backup ...
Reading Phone IDs ...
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 08F001140C368B529971C8428B31C7EA34B1D694
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.34.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.34.0 revision: 2.0 size: 0x8FE30
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: 76A20187051C30162EE91C77AE5E6011F5F1BA61
PRIVATE ID: 66B7880611DAAED79A3D9D265AAE8C337DB22172
E-FUSE: 65FF8B12
SEC ROM CRC: 3E691FF8
productData saved.
Restarting phone ...
Reading Secure Storage ...
Reading Important data ...
Reading SIMLOCK data ...
Reading CERT data ...
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 12.8.0 revision: 2.0 size: 0x3B80
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 12.8.0 revision: 2.0 size: 0x8B49D
Reading CMT NPC (0x190 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Flash Imei: 35798803012888
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
SUPERDONGLE_KEY_DATA saved OK
CMLA_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
WLAN_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35798803012888_BA CK.rpl"
FULL FACTORY... Failed! (0103)
Please Set mode to "TEST MODE" and retry!
Completed in 4.697 s
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 1.718 s
The Following User Says Thank You to pooja_19 For This Useful Post:
Old 11-12-2012, 11:26   #11 (permalink)
Member: 585876
Thanks Meter: 2
thank you its working
[/QUOTE]
Old 11-12-2012, 21:11   #12 (permalink)
Member: 1838604
hello apply this jamper
Old 11-17-2012, 05:56   #13 (permalink)
exit_exit2050's Avatar
Member: 872692
Thanks Meter: 51
thx bro.... my pro.....soll kip it up
Old 07-22-2013, 13:10   #14 (permalink)
Member: 742806
Sonork: 17532048
Thanks Meter: 7
nokia 5800 vivration only i put in lamp 2hours and resuldring but same what can i do ?
Old 11-07-2013, 13:47   #15 (permalink)
3cellcare's Avatar
Member: 1398631
Sonork: 100.1614508
Thanks Meter: 653
good solution i am test 100% set ok ...........................................
br
3cellcare
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.21991 seconds with 9 queries
