Old 06-13-2007, 20:34   #1 (permalink)
Member: 107258
Thanks Meter: 15
Strange 6600 Keypad Problem
Guys,
i got a 6600 to repair ,when i press the 7,8,9 keys i get 1,2,3 on the display .i have flashed the mcu and the ppm files in ufs-3 .What Could Be The Issue Here ,This is Very stange
Amarbir
Old 06-13-2007, 20:50   #2 (permalink)
Member: 154916
Thanks Meter: 4
hi pro
just reflow or push down the 2 crystal ic
B.R
Begato2002
The Following User Says Thank You to Begato2002 For This Useful Post:
Old 06-14-2007, 05:16   #3 (permalink)
markrhi's Avatar
Member: 520956
Thanks Meter: 12
bro,you need to change the kpad ic both..
Old 06-14-2007, 05:27   #4 (permalink)
Member: 350571
Thanks Meter: 920
Originally Posted by Amarbir View Post
Guys,
Amarbir
brother first you have to change the keypad ic i mention in this picture wich ic you need change see this picture and also i attached rar file for track details
i think this solution help you and others
thank you
post reply
by
sree krishna
The Following 2 Users Say Thank You to sree krishna For This Useful Post:
Old 06-14-2007, 06:31   #5 (permalink)
Member: 107258
Thanks Meter: 15
Guys,
I Am Going To Try This Out And Let You Know About This
amarbir
Old 06-14-2007, 06:51   #6 (permalink)
Member: 131336
Thanks Meter: 7
yeah, that's weirdo.. you know once i tied to jumper flex cable 6600 n i make a wrong key ways. n if i pressed right it turn left. heee
Old 06-14-2007, 07:43   #7 (permalink)
Member: 107258
Thanks Meter: 15
Suwanto,
I did Nothing on This Phone Still 7=1 ,8 = 2 ,9 = 3
Amarbir
Old 06-14-2007, 08:15   #8 (permalink)
Member: 107258
Thanks Meter: 15
Guys,
Nothing Happens When i Reflow The IC .I Think i need To Change These 2 IC's
Amarbir
Old 06-14-2007, 08:19   #9 (permalink)
Lhick's Avatar
Member: 333359
Thanks Meter: 91
Maybe there is Short when you put Jumper.
Old 06-14-2007, 08:22   #10 (permalink)
Member: 107258
Thanks Meter: 15
Hi Lhick,
Kindly Explain ,What You Mean
Amarbir
Old 06-14-2007, 15:24   #11 (permalink)
esma23's Avatar
Member: 180173
Thanks Meter: 28
Guys,
Amarbir
Trace up the common line between 1,2 & 3 pads and 7,8 & 9 pads it's shorted... if you have spare (under) keypad try to change it if still the same
u need to change the IC... Try to rehot the keypad ICs and pushed it down until the lead goes out.... but better change it.
6600 keypad problem strange gangadhar121212 Nokia Hardware & Hardware Repair 1 03-13-2010 08:28
Strange 6600 bluetooth problem andy_con WD2 & APE (Symbian Phones) 2 06-02-2009 22:45
strange 6600 mmc problem.. expertz help plz vinkle Nokia Hardware & Hardware Repair 3 11-13-2007 11:59
6600 keypad problem strange kprajeesh4u Nokia Hardware & Hardware Repair 10 09-23-2007 08:00
Strange C55 keypad problem ion4ev Siemens Hardware Repair Area 8 12-27-2006 22:19
Page generated in 0.21729 seconds with 10 queries
