03-14-2008, 18:50 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: Indore
Member: 506648 Status: Offline Sonork: 100.1614254 Thanks Meter: 702 | Nokia 6020 "No Network Found" Please Give Me Solution |
The Following 2 Users Say Thank You to Ankit Verma For This Useful Post: |
08-24-2008, 17:12 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Mobile solution at Pak_Lahore Age: 46
Member: 158032 Status: Offline Thanks Meter: 331 | Me to need good solution or good pm file for 6020 any body have uploaded it tested.... |
The Following User Says Thank You to ..::My3gtech::.. For This Useful Post: |
08-25-2008, 16:31 | #3 (permalink) |
Insane Poster Join Date: Dec 2007 Location: trissur/kerela/india.. Age: 31
Member: 654510 Status: Offline Thanks Meter: 21 | Dont Remove Or Rehot The Pa It Is The Problem Of antena Swicth change It ........... Post Replay ...... |
The Following User Says Thank You to naima For This Useful Post: |
09-24-2008, 17:20 | #7 (permalink) |
No Life Poster Join Date: Nov 2005 Location: UNLOCKING IN GENERAL:) Age: 51
Member: 196126 Status: Offline Thanks Meter: 80 | 6020 no network found When in manual searching shows no network found first check antenna switch change it and if still no network found rehot N7500 helgo if not found or found 1 2 operators change helgo usually it helps if not rehot UPP then reball it (dont think it ll be necessary) GL |
The Following User Says Thank You to radez For This Useful Post: |
10-08-2008, 09:17 | #13 (permalink) |
No Life Poster Join Date: Jun 2007 Location: dhaka,bangladesh
Member: 528679 Status: Offline Thanks Meter: 268 | this kind prob of come to upp,rf ic ,and,antena ic so check rehot first.....if not done then change one by one........... |
The Following User Says Thank You to sopnil For This Useful Post: |
10-08-2008, 10:29 | #14 (permalink) |
Freak Poster Join Date: Dec 2007 Location: Land of Promise
Member: 659309 Status: Offline Thanks Meter: 121 | try to flash and write good pm if no lock i thinks its a hardware problem.. reheat the the filter or the hagar ic.... |
The Following User Says Thank You to kingskie For This Useful Post: |
Nokia 3100/3120 "no network found" problem | nakshatra | Nokia Hardware & Hardware Repair | 5 | 04-10-2010 08:31 |
Nokia 6020 "No Network Found" | Ankit Verma | Nokia Hardware & Hardware Repair | 8 | 03-14-2009 20:35 |
Nokia 6020 "No Network Found" | Ankit Verma | Nokia Hardware & Hardware Repair | 1 | 03-16-2008 07:19 |
Nokia 8800 sirocco gold "no network found" | taisfus | Nokia Hardware & Hardware Repair | 0 | 12-23-2007 05:53 |
6210 "no network found" after 3 sec. | usernome | Nokia Hardware & Hardware Repair | 9 | 11-12-2004 23:18 |
