02-08-2008, 11:58 | #3 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | Friend connect the phone to the ufs and flash the phone. After flashing on screen it is show LOCAL MODE and after all flashing Clear UI setting and phone is ready to work. If phone can't take flashing process then heat the flash IC OR post here log. OR check the phone in hardware. Post result. |
03-07-2008, 02:08 | #6 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | dear remove flash ic and than chk on ufs that it give 1st boot ok or not? if it give 1st boot ok means ur flash ic is faulty,if it gives 1st boot error even u remove flash ic than problem in upp. ..::HUM::.. |
nokia 5610 dead need help urgent | sunny_luthras | Nokia Hardware & Hardware Repair | 3 | 10-05-2009 06:59 |
nokia 3200 dead need help | ameho0102 | Nokia Hardware & Hardware Repair | 1 | 02-08-2008 15:51 |
nokia 6680 dead need help | ...:::JamalMustafa:::... | Nokia Base Band 5 ( BB-5 ) | 2 | 11-23-2007 12:42 |
nokia 3200 dead as the result off incomplete flashing | fedjak | Twisterflasher | 8 | 03-30-2007 11:44 |
