10-11-2006, 18:44 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | Nokia 6111 dead due to charging i got 6111 the guy told me he connected the charging wires other way around (+ to gnd ?) and phone was like that for about 2 hours if i put new battery , phone is turning on and can make calls , when you charge phone become real hot and the ndead again. if you take battery out for long time you can turn phone on again. maybe a bad component ? what to check ? |
10-14-2006, 08:40 | #6 (permalink) |
Member: 21937 Status: Offline Thanks Meter: 279 | didnt thouched the phone yet ... as all charging components are not the same as other nokia phones there is a cristal IC with 4 points there , maybe its a fuse or something ? weird is , if phone stay without battery for a while , i can put battery and charge it till it get hot and dead again |
11-17-2006, 13:15 | #8 (permalink) |
Freak Poster Join Date: Oct 2005 Location: perth aust.
Member: 188959 Status: Offline Thanks Meter: 7 | You need to strip the handset and find which I.C is cooking.Plug charger in, and if you cannot tell which ic is hot, put it to your cheek or lips [ but not straight away in case you burn your skin!!] .If it is the UPP, or UEM, try flowing it, but you are most likey either replacing the IC, if it's not glued, or yes you may actually have to buy a new one -Sorry.. |
02-25-2007, 19:37 | #13 (permalink) |
Freak Poster Join Date: Dec 2004 Age: 47
Member: 101007 Status: Offline Thanks Meter: 27 | i've got few 6111 has the same prob... all of them already tried PA... nothing to do wit it... ueme very hot.. when charge... and when u use power supply to check u'll kno why the phone can charge but will off....and ueme are glued... but sometimes other part prob can produce heat to ueme as well.. if any of ur expert got solution pls... share.. TIA |
sigmatel s90i dead due to software | manish patel122 | Infinity-Box | 2 | 03-23-2010 06:02 |
t68 dead due to 9V input | sakaz | Sony Ericsson Hardware Repair | 0 | 05-11-2008 21:17 |
K310a dead due to cruiser unlock | Tantech | Cruiser Suite | 1 | 03-22-2007 11:15 |
c 100 dead due to overcharging | gsmwiz | Samsung Hardware Repair | 0 | 02-12-2005 03:24 |
SGH-A800 dead due to bad charger | sysop104 | Samsung Hardware Repair | 5 | 05-24-2004 19:50 |
