Old 03-26-2012, 07:22   #1 (permalink)
Registered User
Member: 692932
Sonork: +8801716503593
Thanks Meter: 25
5130c flash problem any bro help
MXKEY Serial: [FT SCR2000 0] - C0849EA2
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Driver: UFS2XX, ver: 3.6.0.0 , NTMP ver: 2.6.0.0
Module ver: 1.0.0.17602(14-06-2011), Library ver: 1.0.0.12920(08-10-2011)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 1C900208E1834650B6146EDA4710B2F0FFC3610E
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 2400 - 0000 8A31 [Samsung ] type: NOR,CMT
ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS is blank/erased.
TransmissionMode: DDR&TX2
Processing MCU file: rm495__07.97.mcusw
[BB5,BB5 ALGORITHM] size: 18.20 MB
Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000
Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
Erase size: 21 MB
CMT NOR area [00000000-000006BF]
CMT NOR area [000006C0-0001FFFF]
CMT NOR area [00040000-000BFFFF]
CMT NOR area [000C0000-0013FFFF]
CMT NOR area [00140000-0137FFFF]
CMT NOR area [01380000-0151FFFF]
erased in 4.922 s
Flash programming ...
Error chk C7012D0103CD000010000000F1
RX2 not responding, please check BSI/cable/pinout !
Error while programming [00] at 0x00040000, Result: 0010
Task failed at (0800001C)!!!
Last RX buffer: C7 01 2D 01 03 CD 00 00 10 00 00 00 F1 72
Old 03-26-2012, 07:26   #2 (permalink)
kathirmobiles's Avatar
Member: 1591177
Thanks Meter: 85
brother try atf light 100% solve
Old 03-26-2012, 08:49   #3 (permalink)
gsmshankarb's Avatar
Member: 1326709
Thanks Meter: 39
try too usb with flash 100000000% done
Old 03-26-2012, 09:28   #4 (permalink)
Member: 157920
Thanks Meter: 6
same problem in nokia 6300 after change charging ic
Old 03-26-2012, 09:43   #5 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
@jashiblimon ,
seems cable issue but check with usb cable. post result
@amdadsab ,
flash fbus testponits goes into thavo (charging ic) , need to replace another or reball ic properly.
Old 03-26-2012, 09:59   #6 (permalink)
sweet4hamza's Avatar
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,377
change the cable and must try on fbus if same and try rehot flash ic
Old 03-27-2012, 13:12   #7 (permalink)
Registered User
Member: 692932
Thanks Meter: 25
usb flash not done usb not reconize
Old 03-27-2012, 13:30   #8 (permalink)
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,377
i already told you not with out fbus flashing done
Old 03-27-2012, 14:04   #9 (permalink)
Registered User
Member: 692932
Thanks Meter: 25
i also change cable any other solution
Old 03-27-2012, 15:42   #10 (permalink)
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,377
rehot rap ic carefully i hope your problem will be solved
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
Page generated in 0.45371 seconds with 9 queries
