Old 11-20-2004, 16:15   #1 (permalink)
Member: 38922
Thanks Meter: 35
NOKIA 6220 Destroyed PowerSwitch >>SOLUTION<<
Hi Mates, PictureRepairSolutions by CyberoptiK goes on.
Based the 6220 destroyed Power switch Problem.
At the Picture you can see the way off the power track..
You can make a jump from:
> GND to everywhere on the PCB who is grounded (e.g Yellow BlankPADS)
> PowON to (Resistor) R305
Note: If you thinking: Why R305, i can also jump directly to R306, this is your Problem..
GreetZ
Old 11-21-2004, 16:41   #2 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
you can place the PCB unit for another ..
bestman.
Old 11-21-2004, 17:00   #3 (permalink)
Azampk's Avatar
Member: 30303
Sonork: 1001579198
Thanks Meter: 17
R306 Both Sides Coming Form Uem Or One Side Is Ground Becouse I Goted Set On Off Switch Broken With Lines I Makes This Line But Set Not Going On Pls Help Me
Sorry For Bad English
******************azam*****************
Old 11-21-2004, 17:25   #4 (permalink)
Member: 38922
Thanks Meter: 35
@Azam, have ya got also Problems maybe with your UEM ? Check up please.
GreetZ
Old 11-21-2004, 20:42   #5 (permalink)
Azampk's Avatar
Member: 30303
Sonork: 1001579198
Thanks Meter: 17
@CyberoptiK
the costemer says it's was working before broken
*****************Azam******************
Old 11-22-2004, 00:26   #6 (permalink)
Member: 38922
Thanks Meter: 35
My customers saying also often that was ok, this was right.. its normal
Check also your switch, update it and resold UEM. Post it.
GreetZ
6220 DESTROYED POWER SWITCH >SolutioN< CyberoptiK Nokia Hardware & Hardware Repair 2 01-16-2009 14:05
Converting nokia 6220 to nokia 6220b ! Armand0 Nokia Hardware & Hardware Repair 1 04-13-2006 18:18
NOKIA 6600 VIBRA PADS >>SOLUTION<< with PIC. CyberoptiK Nokia Hardware & Hardware Repair 0 04-17-2005 13:37
For Sale: Nokia 6600-SE P800-Nokia 6220-open to offers :) Antoniop Sell ur Old and Used Stuff 8 10-20-2004 20:58
Nokia 6200 = Nokia 6220 m_dige UFS2 + UFS3-Tornadoflasher 3 01-21-2004 18:57
Page generated in 0.15557 seconds with 9 queries
