01-02-2005, 06:50 | #1 (permalink) |
Freak Poster Join Date: Oct 2004
Member: 88176 Status: Offline Thanks Meter: 34 | Nokia 6220 thats not charging but the fuse is fine. AND I have tested between the +/- points on the charging sockets to the battery contacts+/- with a multimetre - it went through no problems.( I checked all the contacts, all fine ) is this is the right way to check it ?! if the circuit is complete then why doesnt it charge ? As far as i know I have not had a charging problem that is related to a software fault yet. |
01-04-2005, 14:23 | #2 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | if its chiness bad assmbly boards( you ll find it as second grad boards) 1- upload pm see it is charge with only commercial chargers 2- change uem and do imie writting and see if it charge only with commercial chargers if it is o.k 3- to make the phone accept any chargers you have to change upp yes upp to make the phone charge o.k like normal phones br., |
02-04-2005, 07:33 | #4 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 40
Member: 109036 Status: Offline Thanks Meter: 56 | known problem too flash pm first then if no avail change uem. Upp changing is a headache. but if you have to, that'll be your last option. still an option cause if you want to, don't repair that damned thing. |
nokia 2600 - display NOT CHARGING but charger don't pluged in | PSG | Nokia Hardware & Hardware Repair | 5 | 09-02-2006 20:55 |
nokia 3510i displays:stop,not charging | gedasgsm | Nokia Hardware & Hardware Repair | 4 | 04-27-2005 19:48 |
Nokia 3610 show not charging when connect with charger | TechPhone | Nokia Hardware & Hardware Repair | 2 | 01-27-2004 20:29 |
Hello anybody, my Nokia-3210 is not charging it is showing not charging | varma raj | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 05-25-2003 11:27 |
