Old 11-19-2004, 21:32   #1 (permalink)
trustunna's Avatar
Member: 63279
Thanks Meter: 8
Nokia 6230 not charging
Hi guyz
i have this nok 6230 showing " not charging" when charger is plugged to it.
any one with clue; pls help asap.
thanx
The Following User Says Thank You to trustunna For This Useful Post:
Old 11-19-2004, 22:19   #2 (permalink)
Member: 38922
Thanks Meter: 35
If you are sure that Batt and charger is ok, check then the FUSE.
GreetZ
The Following 2 Users Say Thank You to CyberoptiK For This Useful Post:
Old 11-21-2004, 15:58   #3 (permalink)
trustunna's Avatar
Member: 63279
Thanks Meter: 8
Fuse , battery and charger are all ok. I've re-flashed phone but still no luck.
Old 11-21-2004, 16:13   #4 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
your phone discharged current from .... try rise pins from charging unit to charging interface. try this now..
bestman.
The Following User Says Thank You to bestman For This Useful Post:
Old 11-21-2004, 16:26   #5 (permalink)
Ciubaka's Avatar
Member: 42304
Thanks Meter: 12
or try changing the charging diode
The Following User Says Thank You to Ciubaka For This Useful Post:
Old 11-21-2004, 16:28   #6 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
your application can be very correct fro this situation ...... keep it up mate.
bestman.
Old 11-21-2004, 18:36   #7 (permalink)
Member: 82155
Thanks Meter: 33
please where will i get the fuse of the set any diagram to show it please
The Following User Says Thank You to gbada For This Useful Post:
Old 11-22-2004, 07:18   #8 (permalink)
COMPAQ's Avatar
Member: 18462
Thanks Meter: 30
buddy firat of all try with a new battery .many times in dct 4
The Following User Says Thank You to COMPAQ For This Useful Post:
Old 11-28-2004, 16:52   #9 (permalink)
trustunna's Avatar
Member: 63279
Thanks Meter: 8
thanks guyz
i will change the charging diode and post reply
Old 04-23-2009, 14:04   #10 (permalink)
Member: 699570
Thanks Meter: 6
sir plzzzzzzzzzzz send me dygram 6230i charging fuse
Old 04-23-2009, 14:53   #11 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
Bro.chack it...
The Following 5 Users Say Thank You to mahbubalfa For This Useful Post:
Old 04-24-2009, 18:42   #12 (permalink)
Member: 771642
Sonork: aanshu55
Thanks Meter: 28
hi bro u try removing C100 and C101 one bye one if not ok change R100 47k. may be problem solve.
Old 05-08-2010, 07:25   #13 (permalink)
Member: 1296414
Sonork: au
what if the fuse is not showing continuity
Old 07-13-2010, 15:18   #14 (permalink)
Member: 1113899
Thanks Meter: 39
not work.............
Old 01-27-2011, 08:22   #15 (permalink)
Member: 631185
Thanks Meter: 15
i alsoo chan these part but problim not solve
nokia 6230 not charging barthosyn Nokia Hardware & Hardware Repair 3 12-24-2009 19:05
nokia 6230 not charging needed pls. barthosyn Nokia Hardware & Hardware Repair 0 11-27-2009 19:05
nokia 6230 not charging display rahmanp Nokia Hardware & Hardware Repair 5 11-10-2009 17:15
Nokia 6230 - Not Charging. Charger Port Contact Problem? sandrock2005 Nokia Hardware & Hardware Repair 0 03-17-2006 01:49
nokia 6230 not charging ,please ? eng.hamdow Nokia Hardware & Hardware Repair 1 07-29-2005 21:45
Page generated in 0.25097 seconds with 9 queries
