Old 07-03-2008, 22:56   #1 (permalink)
Member: 429524
Thanks Meter: 3
Question Nokia 6280 Headphone Icon
Hello,
I have searched a lot for the Nokia 6280 problem and its solution. Some point I still havent got cleared as I couldnt found them anywhere.
If I switch the phone I hear Nokia startup voice as normal from speakers. But as soon as it gets to the main phone software it shows a headphone icon on the top. I cant hear anything even connecting a headphone (playing any media file)
Now is it a hardware problem or software problem?
If you say its pop port problem. Then why nokia start up voice comes from speakers phone. And do anybody have a step by step pop port removal video or instruction?
OR is there any other shortcut to this problem by using jumpers.
The Following User Says Thank You to aaho For This Useful Post:
Old 07-03-2008, 23:06   #2 (permalink)
Crazy Poster
Member: 582265
Thanks Meter: 5
just connect your 6280 headphone and switch off your phone with connected head phone and switch on your phone with connected head phone and out the head phone after this your problem will be solve 100% i say.
Old 07-04-2008, 07:39   #3 (permalink)
Member: 429524
Thanks Meter: 3
no its not working ankitmodi.
I have JAF. I have flashed it just to check if there is any software problem. After flashing its still the same. I have tried to boot it into normal mode using JAF. it booted normal and without headset icon. but again when I boot it with putting battery the headset icon comes again. I think may be there is some problem with battery connection.
Old 07-04-2008, 08:10   #4 (permalink)
Member: 451235
Wink try this
Originally Posted by aaho View Post
Hello,
men just try changing its ic if ic is short or any of headphone related components than change that and u will get success.first remove ic and than check whether still that sign persists or nt
Old 07-04-2008, 08:24   #5 (permalink)
Member: 429524
Thanks Meter: 3
which IC are you talking about?
Old 07-04-2008, 10:03   #6 (permalink)
Member: 707088
Sonork: moonstarmobile
hey man
hey man the startup tone is cming from buzer if u seen a headphone icon in ur telephone just give hot to popport connector ( headphone jack)
after that its 100% ok i have more experienced in this problem & i rectified this prblm many more times
Old 07-04-2008, 11:24   #7 (permalink)
Member: 429524
Thanks Meter: 3
I got an idea about buzzer..
how much heat must be given and at what specific area. Can you explain a little?
thanks
Old 07-04-2008, 23:22   #8 (permalink)
Member: 429524
Thanks Meter: 3
anybody can say anything to help in this regard?
Old 07-04-2008, 23:26   #9 (permalink)
Crazy Poster
Member: 752056
just open it up and clean it
i have encountered this problem many times and 100% working all times take it apart and clean it with a brush and heat it cuz its shorting
Old 07-05-2008, 05:01   #10 (permalink)
gsmstroong's Avatar
Member: 302306
Thanks Meter: 44
6280 Hand Free Solution
HI aaho
BRO 1ST OF ALL CHANGE HAND FREE JAKE THEN CHANGE THESE ICS
ONE BY ONE I HOPE YOUR PROBLEM WILL BE FINE
BEST REGARDS
GSM STROONG
The Following User Says Thank You to gsmstroong For This Useful Post:
Old 07-05-2008, 09:36   #11 (permalink)
Member: 639286
Thanks Meter: 27
Just clean up Your Handsfree Connector it will be solved.
Old 07-05-2008, 21:50   #12 (permalink)
Member: 429524
Thanks Meter: 3
I have tried to clean it with normal tissue but the same. Is there any specific way to clean it?
Thanks gsmstroong. I will use it as my last option.
Old 07-05-2008, 23:27   #13 (permalink)
AdickAsia's Avatar
Member: 801083
Thanks Meter: 99
Why this condition happen??.
This condition happen, because swicth headset on automatic in few secon after phone startup. You have to look for polar capasitor that semi shorted. try step by step solution :
1. clean, replace or change ur plug in.
2. change or remove all polar capasitor there conected with all pin in ur plug in.
3. Change ur jeck
1-3 -- many phone in this condition
4. Ur power IC, -- clean, replace ..
good luck sir
Old 07-08-2008, 14:35   #14 (permalink)
gsmstroong's Avatar
Member: 302306
Thanks Meter: 44
Hi What Is The Condition Of 6280.
B/r
Old 07-08-2008, 17:09   #15 (permalink)
Member: 762183
Thanks Meter: 11
Arrow
brother check this i hope your problem is solve....
nokia ngageQD headphone rezabhai Nokia Hardware & Hardware Repair 0 09-23-2008 11:45
nokia 3220 headphone on screen jacob magembe Nokia Hardware & Hardware Repair 5 04-09-2008 12:46
Nokia Bluetooth HeadPhone Device NokiaMobileCare Nokia Hardware & Hardware Repair 3 12-27-2007 19:44
6680 showing headphone icon citylight Nokia Hardware & Hardware Repair 4 10-20-2007 23:26
nokia 6101 headphone symbol Johnessen Nokia Hardware & Hardware Repair 1 08-24-2006 06:25
Page generated in 0.30074 seconds with 10 queries
