Old 02-29-2008, 15:29   #1 (permalink)
StRaNgE PeRsOn's Avatar
Member: 391445
Sonork: 100.1583575
Thanks Meter: 392
<<<...Nokia 6280 Restarting problem...>>>
hi....
i am having continuously 3rd problem in 6280
any solution so plz post here......
tried everything on software but same.....
plz do help...
Old 02-29-2008, 16:04   #2 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,510
I also have the same problem on 6288. I flashed the phone several times with several versions but the problem is same.
Old 02-29-2008, 18:23   #3 (permalink)
Member: 230911
Thanks Meter: 177
I have same problem. I have flashed the phone many times using usb or fbus cable but no sucess
Old 02-29-2008, 18:48   #4 (permalink)
acay's Avatar
Member: 197916
Thanks Meter: 157
hardware problem bro!!!
try change ahne!!!
Old 03-01-2008, 09:12   #5 (permalink)
Member: 228508
Thanks Meter: 55
yes. hardware problem
change flash
Old 03-01-2008, 09:18   #6 (permalink)
Member: 391445
Sonork: 100.1583575
Thanks Meter: 392
HOw come flash problem man?????
it restarts on visual programs like camera and video clips including any format....
plz post any possible solution
Old 03-01-2008, 13:33   #7 (permalink)
Swazi_Gsm's Avatar
Member: 317494
Sonork: 1000.1984
Thanks Meter: 187
first flash with same proudect code bro problem will solve neither not then change flex neither not then reboot rap3g
Old 03-01-2008, 14:15   #8 (permalink)
That'sme's Avatar
Member: 228871
Thanks Meter: 43
I had same problem With 6280 i flashed and flex too.
my problem just solved by changing the LCD. Just give a try and see
Old 03-01-2008, 22:24   #9 (permalink)
beerfoote1's Avatar
Member: 220143
Thanks Meter: 108
I have 6280 with powering off problems too. It just powers up to the Nokia start up sign and then powers off. How do I solve this ?
Thanks
Old 03-01-2008, 22:28   #10 (permalink)
Member: 5021
Thanks Meter: 3
Thanks
Try change the flex cable, maybe swich is your problem...is blocked, or maybe swich plastic front
Old 03-04-2008, 20:12   #11 (permalink)
Member: 647152
if restart 4 times and switched off ????
try to flash and formatt
Old 03-05-2008, 03:11   #12 (permalink)
Registered User
Member: 557494
Thanks Meter: 14
try to replace the crystal memory bother and flash it to the latest version...
Old 03-05-2008, 03:28   #13 (permalink)
Member: 683466
Originally Posted by StRaNgE PeRsOn View Post
hi....
plz do help...
try to change the LCD or the FLEX cable of your phone, then post the result
Old 04-29-2008, 05:30   #14 (permalink)
Crazy Poster
Member: 144686
Flashing screen on 6280-6288
Just flash it with JAF!!!! WORKS EVERY TIME!
Will it does for me anyway.
GOOD LUCK!
Old 04-29-2008, 14:18   #15 (permalink)
Member: 647152
restarting 4 times is a software problem .try to full flash and formatt it will ok..............
<<< Lg Kg 195 Restart Problem >>> Faisal_Computer VygisToolbox 4 12-14-2009 11:46
<<< Nokia 5130 Succesfull Flash >>> Shakeel_pattoki MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 11-18-2009 15:35
<<< Lg Kg 195 Restart Problem >>> Faisal_Computer Infinity-Box 5 07-21-2008 16:14
nokia 6280 restarting problem turbro Nokia Hardware & Hardware Repair 6 12-04-2007 18:03
Page generated in 0.22092 seconds with 9 queries
