10-17-2008, 05:14 | #2 (permalink) |
No Life Poster Join Date: Mar 2007 Location: INDIA
Member: 463150 Status: Offline Thanks Meter: 91 | 1= change ur battery 2= change the charger if problem still not solved 3= simply reball thavo .. And ur problem will be solved tested....... |
The Following User Says Thank You to vishal123123 For This Useful Post: |
10-17-2008, 05:41 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Bareilly(U.P) Age: 50
Member: 405715 Status: Offline Thanks Meter: 271 | 6300 charging fault change charging ic tahvo. shown in picture red marked |
The Following User Says Thank You to shuaib_kashish For This Useful Post: |
10-17-2008, 05:49 | #4 (permalink) |
No Life Poster Join Date: Jan 2007 Location: agrabad,ctg,Bangladesh Age: 41
Member: 426688 Status: Offline Sonork: 100.1596204 Thanks Meter: 524 | bro, put charger to the handset and check to the battery connector(without battery) how much volt output if out put is 3.7-4.00 volt, then change battery if output is not ok then you can change tahvo(at 1st try to rehot) best of luck post your result |
The Following User Says Thank You to jimm07ct For This Useful Post: |
6120 charging not save help me argent | GSMTURBO | Nokia Hardware & Hardware Repair | 18 | 07-02-2010 13:58 |
china A200 charging not save help me plz | shani72 | Chinese Models & Cloned Phones | 0 | 12-28-2009 11:47 |
N70 charging not save help me | zahed1978 | Nokia Hardware & Hardware Repair | 3 | 08-25-2009 08:16 |
n73 camera ok but image not save,help me | shivam4you | Nokia Hardware & Hardware Repair | 5 | 03-07-2009 19:44 |
nokia 6300 dead after flahing plz help me | nishatmohd | Nokia Hardware & Hardware Repair | 9 | 02-06-2009 19:22 |
