03-03-2009, 10:24 | #1 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 395897 Status: Offline Thanks Meter: 56 | nokia 6300 problem i have a nokia 6300 when the battery gets empty it never charge it on the mobile again when i put the charger the side blue lights blinks so i must charge it using an external charger.. i mean the mobile charge the battery when there is power inside it but when empty never charge. i changed battery and the charger and still the same problem..!! any ideas!!! thanks for all. |
The Following User Says Thank You to roy_naber For This Useful Post: |
03-09-2009, 05:20 | #4 (permalink) |
Insane Poster Join Date: Dec 2008
Member: 915413 Status: Offline Thanks Meter: 7 | change diode, your problem will be solved post reply,shivam [email protected] |
04-02-2009, 16:46 | #5 (permalink) | |
No Life Poster Join Date: May 2008 Location: arth'*****
Member: 776884 Status: Offline Sonork: techno-gsm Thanks Meter: 152 | Quote:
06-26-2009, 21:36 | #9 (permalink) |
Junior Member Join Date: Nov 2008
Member: 909622 Status: Offline Sonork: [email protected] Thanks Meter: 8 | I have a issue ,6300 imei not showing *#06# = i want to input a new imei and it must work with the code (*#06#) to check imei , please can you give some guide line how can i overcome this issue... also the other problem is if i dont use it for few minutes phone is auto off. Battery is Fine, what can be the possible reason and how it can be resolved. pls explain... Thank you in advance |
nokia 6300 problem | bassemzini | Nokia Hardware & Hardware Repair | 3 | 04-24-2009 10:02 |
nokia 6300 problem | ric wong | Chinese Models & Cloned Phones | 0 | 02-24-2009 07:49 |
china nokia 6300 problem | asad_nomy7 | Infinity-Box | 1 | 06-05-2008 21:51 |
nokia 6300 problem | psilva | Nokia Base Band 5 ( BB-5 ) | 3 | 05-10-2008 21:07 |
nokia 6300 problem | rem_drive | Nokia Hardware & Hardware Repair | 5 | 04-07-2008 16:52 |
