04-14-2009, 18:19 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Gsmhosting Age: 47
Member: 142191 Status: Offline Sonork: 100.1589775 Thanks Meter: 297 | nokia 6300 strange blue lights problem. need help. got one nokia 6300 in dead condition...customer told me that set was dead after battary low. i first replace tahvo ic..now set is working ok only on flashing box...but with battary only blue lights..i again replace tahvo but same problem.. i tried these things 1. flash phone with latest version flash file even also try after erasing. all is going ok during flashing i mean local mode test mode etc. 2. replace thavo 2 times. 3. replace retu also. 4. reballed flash chip. 5. all the jumper solutions which i find in this great forum. 6. also clean the test points and complete board as well. now i m confused what to do with this half dead half on set.( set is on with flashing box but with battary blue lights only ) plz help experts..thanx. |
The Following User Says Thank You to rk_grover77 For This Useful Post: |
04-14-2009, 18:47 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Bangladesh Age: 38
Member: 1003058 Status: Offline Sonork: 100.1589274/mahbubalfa Thanks Meter: 26,433 | Bro....u chack battry conector midele pin OHM.....reusult post here........ |
The Following User Says Thank You to mahbubalfa For This Useful Post: |
04-15-2009, 05:14 | #3 (permalink) |
No Life Poster Join Date: Jan 2008 Location: india
Member: 681945 Status: Offline Thanks Meter: 422 | i have told u first to check battery connectors and bsi path,u do that ? check bsi shorting,the zanor diod and capacitor parler to ground may be leaking, remove them. and post result boss. |
The Following User Says Thank You to kapilgupta For This Useful Post: |
04-15-2009, 05:20 | #4 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Jalandhar Age: 39
Member: 580966 Status: Offline Sonork: 100.1590311 Thanks Meter: 725 | plug in charger and see is it show charging/not. If Yes then power ways faulty. If no then check Bsi line. Br Karan |
The Following 2 Users Say Thank You to KK Mobile For This Useful Post: |
04-15-2009, 05:46 | #5 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Pune (Daund) Maharashtra Age: 34
Member: 787710 Status: Offline Sonork: not using Thanks Meter: 771 | [IMG][/IMG] BROTHER TRY This... HOpe Ur Probleme WIll SOLVE... ..................:::::::::::::SURAJ::::::::::::................. |
The Following 4 Users Say Thank You to suraj9860607689 For This Useful Post: |
04-15-2009, 06:33 | #7 (permalink) |
Member: 580966 Status: Offline Sonork: 100.1590311 Thanks Meter: 725 | @rk_grover77 Brother Fix same version/higher version thavo which its origanally had. post results Br Karan |
04-15-2009, 11:28 | #8 (permalink) |
Member: 142191 Status: Offline Sonork: 100.1589775 Thanks Meter: 297 | problem solved..........just changed the components connected to bsi lines...now set is working fine. thanx everybody who helps me to solve that problem. |
The Following 2 Users Say Thank You to rk_grover77 For This Useful Post: |
Nokia 6300 side blue light on | ravi mobile | Nokia Base Band 5 ( BB-5 ) | 7 | 01-05-2011 18:26 |
6300 Very Strange Blue Light Only Already Flash And Check Hardware | MUTUAL | Nokia Hardware & Hardware Repair | 14 | 05-19-2010 07:21 |
nokia 6300 only side light problem help me | arifm_cools | Nokia Hardware & Hardware Repair | 3 | 08-11-2009 05:36 |
6300 blue light problem | sigamani | Nokia Hardware & Hardware Repair | 4 | 12-28-2008 06:46 |
nokia 1600 light problem need help | khalidbaig | Nokia Hardware & Hardware Repair | 3 | 11-21-2008 09:01 |
